Ask an Expert Forum "setTargetAddress not defined" Error in Cloud9: BeagleBone Black running Debian 7.9eMMC
  • Subscribers 306 subscribers
  • Views 616 views
See a helpful answer?
I'm a beginner on BBB JS programming, just playing around with examples.
Following
BeagleBone Black Cookbook Webinar Series: Recipe #2- Displaying GPIO status in a Web Browser
After I paste the code:
setTargetAddress('192.168.7.2',
{initialized: run}
function run() {
var b = require('bonescript');
b.pinMode('P8_19', b.INPUT);
getButtonStatus();
function getButtonStatus() {
b.digitalRead('P8_19', onButtonRead);
function onButtonRead(x) {
$('#buttonStatus').html(x.value);
setTimeout(getButtonStatus, 20);
into cloud9, it says there is an error in  first line: "setTargetAddress not defined"
What's problem here? Did I need to install anything?
Thanks!
    OK, setTargetAddress() is a function defined in bonescript.js and it located in /var/lib/could9/static/ , do I need do anything to call this function? If so, what should I do?
    0 Former Member over 10 years ago in reply to Former Member
    I added this  in the first line:
    var jQueryDemo = require(./static/bonescript.js);
    and I get the error:
    require, module, __filename, __dirname) { var jQueryDemo = require(./static/b
    SyntaxError: Unexpected token .
        at Module._compile (module.js:439:25)
        at Object.Module._extensions..js (module.js:474:10)
        at Module.load (module.js:356:32)
        at Function.Module._load (module.js:312:12)
        at Module.runMain [as _onTimeout] (module.js:497:10)
        at Timer.listOnTimeout [as ontimeout] (timers.js:110:15)
    any suggestion?
