Ask an Expert Forum Hello, I have a Imo PA20101footswitch which I want to use with my scroll saw,  can anyone provide me with a wiring diagram or otherwise tell me how to do it.   Thank you.  P.J.Arnold.
  • Subscribers 340 subscribers
  • Views 879 views
  • pa20101
  • imo
  • footswitch
See a helpful answer?
Hi I have an Imo  PA20101PA20101 footswitch which I intend to use with my scroll saw can anyone provide me with a wiring diagram or otherwise tell me how to do it Thank you P.J.Arnold
  • clem57
    0 clem57 over 10 years ago
    Have you seen datasheet?
  • D_Hersey
    0 D_Hersey over 10 years ago
    http://www.farnell.com/datasheets/7002.pdf
    This switch seems to be dual spst.  Typically we switch stuff on the AC line by interrupting the 'hot' line which corresponds to the thinner blade in the USA.  That is also the side for fuses.
    0 jw0752 over 10 years ago
    Hi Patrick,
    I would recommend something like this as a cord:
    http://www.amazon.com/Stanley-31324-CordMax-Polarized-Extension/dp/B003E46M60/ref=sr_1_12?ie=UTF8&qid=1452840528&sr=8-12&keywords=switch+power+cord
    If you remove the switch from the end and wire it to your foot control you can plug the cord into the outlet and then plug your saw into the receptacle on  back of the plug. I could not easily find a listing but I know this cord switch is also available in a three wire configuration too. Based on the information that  D_Hersey found for you the best you can do is turn the saw on and off. You will want to use the NO (Normally Open) contacts on the switch inside the foot control. Make sure you secure the cord with a strain relief inside the foot control so the wires can't pull loose accidentally.
    0 e14 Contributor over 10 years ago in reply to clem57
    Thank you for that I`ll have a go.
    0 e14 Contributor over 10 years ago in reply to jw0752
    Thanks very much I`ll try it.
    Thank you for that I`ll try it.
