Ask an Expert Forum Help Identifying a Female Socket Type
  • Subscribers 339 subscribers
  • Views 583 views
See a helpful answer?
adamg
adamg over 10 years ago
Hello All,
I was wondering if anyone can help me identify the socket in the photo attached so that i can purchase the male plug equivalent?
It's for a subwoofer with an inbuilt amp running on a 12v system (car). Max current is 14A.
Any help is very much appreciated.
Adam
  • adamg
    adamg over 10 years ago +1
    Fantastic. You are a champion Paul. Many thanks. To utilise this plug is it as simple as purchasing these crimps: 39-00-0039 - MOLEX - Contact, Mini-Fit Jr. , 5556 Series, Socket, 24 AWG, 18 AWG, Crimp…
  • gadget.iom
    0 gadget.iom over 10 years ago
    This looks it could be like the plug you are looking for:
    http://uk.farnell.com/molex/39-01-2100/receptacle-mini-fit-10way/dp/151870
  • adamg
    0 adamg over 10 years ago
    39-00-0039 - MOLEX - Contact, Mini-FitRegistered Jr.Tm, 5556 Series, Socket, 24 AWG, 18 AWG, Crimp, Brass | Farnell element14
    Crimp them onto the applicable cables and then push them into the plug. I assume they will simply lock in once pushed into the plug?
    If you have a moment to help me learn, was there a particular term for the rounded off pins as opposed to the bottom pins?
    Once again, many thanks Paul.
  • gadget.iom
    0 gadget.iom over 10 years ago in reply to adamg
    Yes. AFAIK they should just push into place. There is usually a barb on the pin that patches into the plastic housing.
