Ask an Expert Forum Understanding how/why Arduino works?
  • Replies 11 replies
  • Subscribers 320 subscribers
  • Views 1745 views
See a helpful answer?
Hi, I am really interested in learning electronics (which I know virtually nothing about). I saw some videos about Arduino and RPi, and think they're really cool.
But I have one problem with these products. They're already made for you, and you simply use them. I can see how the Arduino can be useful for electronics projects, but it doesn't really tell me how/why the Arduino does what it does.
I would like to know how to create my own circuit, from scratch, that can do what the Arduino/RPi does. Is this possible, or too difficult?
I really want to have a low-level understanding of electronics. I don't know where to start, or what resources would be helpful.
EDIT: Like, for example, I would like to be able to get into the mindset of the people who made the Arduino/RPi, and understand how they made them and everything they knew about the various components (chips on the circuit, pins, capacitors, etc.)
Thanks in advance,
Alex.
  • Robert Peter Oakes
    0 Robert Peter Oakes over 10 years ago
    So if your new to electronics and want to learn how things work
    DON'T Start with Arduino or a PI, start with Electronics (Here is an example of a project with no computing in it at all and you can end up with a useful bit of kit at the end of it
    The Modular Bench Power Supply ++, The Essential DIY Build for Every EE Student and Old Timer alike...
    there are 15 1Hr ish videos there already and more will be coming, I cover many simple (Relative I know) topics needed to complete the project and try to explain how each part works without too much or any theory, all practical examples where I can, you will find Voltage References, Power Transistors, OP-Amps, Integrator, summing amplifiers, a DC Load Side project (Also very useful in its own right)
    There are many other great examples of electronic projects that can provide a similar learning experience. This way there are NO micro-controllers hiding the way things work
    I know for my videos, the next round will be introducing micro-controllers into the system but by then you would have enough knowledge to handle it wisely and there is no need to even add the micro-controller if you don't want to
    So when you have a basic understanding of the electric components then you can move on to controlling them with an Arduino or a PI or Launch Pad or CHIP, or CodeBug, Or image You get the idea, there are so many to choose from
    Walk before you run is the tip for the day
