Ask an Expert Forum Raspberry Pi Wireless AccessPoint issue with WiPi Dongle
  • Replies 18 replies
  • Subscribers 341 subscribers
  • Views 25201 views
  • wifi dongle
  • wap
  • wireless accces point
  • wipi
See a helpful answer?
pbhound
pbhound over 10 years ago
Hello all, I need assistance with an issue.
I am trying to configure my Pi as a Wireless Access Point (WAP).
I have it all configured according to the Adafruit Guide https://learn.adafruit.com/setting-up-a-raspberry-pi-as-a-wifi-access-point/overview
When I run "sudo /usr/sbin/hostapd /etc/hostapd/hostapd.conf"
I get the following error:
     Configuration file: /etc/hostapd/hostapd.conf
     Line 4: unknown hw_mode "N"
     1 errors found in configuration file '/etc/hostapd/hostapd.conf'
the content of my hostapd.conf file is such:
     interface=wlan0
     driver=rt2870
     ssid=Pi_AP
     hw_mode=N
     channel=6
     macaddr_acl=0
     auth_algs=1
     ignore_broadcast_ssid=0
     wpa=2
     wpa_passphrase=Raspberry
     wpa_keymgmt=WPA-PSK
     wpa_pairwise=TKIP
     rsn_pairwise=CCMP
I have tried it with "g" and with "n" and get the same error (with "g" and "n" respectively)
If I comment out "hw_mode=N" I get the following error
     configuration file : /etc/hostapd/hostapd.conf
     dry->ifindex=3
     l2_sock_recv==l2_sockxmit=0x0f3e638
     IOCtl[SIOCSIWMODE]:invalid arugment
     could not set interface mode(3)!
     could not set interface to master mode!
     rtl871xdrv driver initialization failied.
My wireless adapter is from element 14 https://www.element14.com/community/docs/DOC-69361/l/wifi-usb-dongle-for-raspberry-pi#cblogposts
I have the drivers for the device placed It into the /bin folder.
any and all help will be greatly appreciated
Thank you
  • pbhound
    0 pbhound over 10 years ago in reply to clem57
    This is what the lsusb gets me. so I take it that the driver that I need is the rt5370?
    Bus 001 device 002: ID 0424:9514 Standard Microsystems Corp.
    Bus 001 device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 001 device 003: ID 0424:ec00 Standard Microsystems Corp.
    Bus 001 device 004: ID 148f:5370 Ralink Technology , Corp. RT5370 Wireless Adapter
  • clem57
    0 clem57 over 10 years ago in reply to pbhound
    So the chipset show work. I am going to try on my Raspberry Pi Model B with a different chipset over next few days.
    Clem
  • pbhound
    Sorry Clem about the late reply, here is the result of the command:
    sudo /usr/sbin/hostapd -d /etc/hostapd/hostapd.conf
    random: Trying to read entropy from /dev/random
    drv->ifindex=3
    l2_sock_recv==l2_sock_xmit=0x0xc76638
    ioctl[SIOCSIWMODE]: Invalid argument
    Could not set interface to mode(3)!
    Could not set interface to master mode!
    rtl871xdrv driver initialization failed.
  • clem57
    This tells me the driver loaded is not the one you need for your hardware. I am getting close to setting up mine so I can help you.
    Try this ->  driver=rtl871xdrv
    or this -> driver=nl80211
    Let me which works,
    Clem
  • pbhound
    so by using  driver=rtl871xdrv i get
    Line 4: unknown hw_mode 'n'
    and with driver=nl80211 i get
    Line 2: invalid/unknown driver 'nl80211'
    2 errors found in configuration file '/etc/hostapd/hostapd.conf'
    the first one works for the driver but it looks like it doesnt support 802.11N
  • pbhound
    hmmmm. must be a good question...
  • pbhound
    any ideas?
  • deepankarmaithani
    0 deepankarmaithani over 9 years ago in reply to pbhound
    Did you solve the issue? I am using the same dongle. Here is something that i think you might find intresting https://github.com/lostincynicism/hostapd-rtl8188. I am also trying for solution will update
