Ask an Expert Forum Raspberry Pi Wireless AccessPoint issue with WiPi Dongle
  • Replies 18 replies
  • Subscribers 341 subscribers
  • Views 25246 views
  • wifi dongle
  • wap
  • wireless accces point
  • wipi
See a helpful answer?
pbhound
pbhound over 10 years ago
Hello all, I need assistance with an issue.
I am trying to configure my Pi as a Wireless Access Point (WAP).
I have it all configured according to the Adafruit Guide https://learn.adafruit.com/setting-up-a-raspberry-pi-as-a-wifi-access-point/overview
When I run "sudo /usr/sbin/hostapd /etc/hostapd/hostapd.conf"
I get the following error:
     Configuration file: /etc/hostapd/hostapd.conf
     Line 4: unknown hw_mode "N"
     1 errors found in configuration file '/etc/hostapd/hostapd.conf'
the content of my hostapd.conf file is such:
     interface=wlan0
     driver=rt2870
     ssid=Pi_AP
     hw_mode=N
     channel=6
     macaddr_acl=0
     auth_algs=1
     ignore_broadcast_ssid=0
     wpa=2
     wpa_passphrase=Raspberry
     wpa_keymgmt=WPA-PSK
     wpa_pairwise=TKIP
     rsn_pairwise=CCMP
I have tried it with "g" and with "n" and get the same error (with "g" and "n" respectively)
If I comment out "hw_mode=N" I get the following error
     configuration file : /etc/hostapd/hostapd.conf
     dry->ifindex=3
     l2_sock_recv==l2_sockxmit=0x0f3e638
     IOCtl[SIOCSIWMODE]:invalid arugment
     could not set interface mode(3)!
     could not set interface to master mode!
     rtl871xdrv driver initialization failied.
My wireless adapter is from element 14 https://www.element14.com/community/docs/DOC-69361/l/wifi-usb-dongle-for-raspberry-pi#cblogposts
I have the drivers for the device placed It into the /bin folder.
any and all help will be greatly appreciated
Thank you
  • gadget.iom
    0 gadget.iom over 10 years ago
    Are you using uppercase or lowercase "n"?
    Much of the available documentation shows lowercase statements, though I can't determine wether that actually matters anyway.
    Have you tried adding the following line to the file:
    ieee80211n=1
  • pbhound
    0 pbhound over 10 years ago
    @Paul Ellison
    I have tried with "n" as stated in original post but get the same error.
  • gadget.iom
    0 gadget.iom over 10 years ago in reply to pbhound
    Did adding the ieee line help?
  • pbhound
    0 pbhound over 10 years ago in reply to gadget.iom
    @Paul Ellison,
    no that did not work it returned the following error
    drv-ifindex=3
    l2_sock_rec v==l2_sock_xmit=0x0x5fb638
    ioctl[SIOCSIWMODE]: Invalid argument
    could not set interface to mode (3)!
    rtl2870xdrv driver initialization failed.
  • gadget.iom
    Ok. Which WiFi dongle are you using?
  • clem57
    0 clem57 over 10 years ago
    Please try this for more debuging information:
    sudo /usr/sbin/hostapd -d /etc/hostapd/hostapd.conf
    Clem
  • clem57
    0 clem57 over 10 years ago in reply to clem57
    Please see the following. It would help if you give the output of lsusb command to see the chip set.
    Please make sure you Wifi dongle supports Access Point or Master Mode
    • Edimax doesn't support Access Point (UPDATE 8/22/15: Edimax DOES support Access point, hostapd 2.4 with rtl driver: Hostapd-rtl8188)
    • AirLink 101 / AWL5088 doesn't support Access Point
    • Panda Ultra, Mid-Range and 300Mbps Wireless N Adapters support Access Point
    • Ralink RT5370 supports Access Point
  • pbhound
    this is the one I am using https://www.element14.com/community/docs/DOC-69361/l/wifi-usb-dongle-for-raspberry-pi#documents
  • pbhound
    0 pbhound over 10 years ago in reply to clem57
    can you provide the command please?  kind of new to Linux... I know enough to make me dangerous.
    thanks
  • clem57
    0 clem57 over 10 years ago in reply to pbhound
    lsusb
