Ask an Expert Forum I2C Clock Stretching feature in Raspberry Pi 3
  • Subscribers 329 subscribers
  • Views 2007 views
See a helpful answer?
Hi all,
I have a sensor that uses the I2C clock stretching feature, but the Raspberry Pi 2 versions do not included this feature.  I have to run the I2C clock at the slowest speed to communicate with minimum errors.  Does the Raspberry Pi 3 offer this clock stretching feature?
Don
  • gps-pie
    gps-pie over 6 years ago +1 suggested
    Ignore what it says on the Adafruit website about using only serial connection to the Raspberry Pi. This is incorrect. The Raspberry Pi i2c hardware does have a bug which prevents the BNO055 IMU operating…
  • clem57
    0 clem57 over 10 years ago
    Well this one is supported at the hardware level, but the software drivers do not implement. See Advamation - Know-How - Raspberry Pi I2C Bug
    for the way to workaround the issue. But are you forced to use this feature? This seems to not be a universal feature for other MCU's either.
    Clem
    0 Former Member over 10 years ago in reply to clem57
    Thanks for the link, it is helpful to understand the issue.  I don't believe I can disable the clock stretching done by the sensor.  So with the pi 3, it is a matter of time that the drivers will be updated to included this "feature?"
  • clem57
    0 clem57 over 10 years ago in reply to Former Member
    I would open dialog on Raspbian - eLinux.org  since they say at the top
    Did you know that elinux.org has Mailing Lists? Please feel free to register today to discuss the wiki in general, request features, etc. etc.. Thanks!--Wmat (talk)
    I hope you get a positive response. I would if I had that sensor. BTW, what is it?
    Clem
    Thanks, Clem, I have looked at some other websites including the elinux.org.  The sensor is the bno055.
  • clem57
    I found they use the UART instead in https://learn.adafruit.com/bno055-absolute-orientation-sensor-with-raspberry-pi-and-beaglebone-black/hardware
    Clem
  • gps-pie
    0 gps-pie over 6 years ago
    The Raspberry Pi i2c hardware does have a bug which prevents the BNO055 IMU operating correctly. However this can easily be overcome by disabling the standard i2c hardware entirely, replacing it with a software based i2c device already present in the kernel by using a device tree overlay. This software based i2c device correctly implements the i2c protocol clock stretching. This will allow the BNO055 to be used with the Raspberry Pi. For full details of the procedure please see https://gps-pie.com/pi_i2c_config.htm
