Ask an Expert Forum Is this antenna compatible?
  • Subscribers 339 subscribers
  • Views 1024 views
  • frontpage
  • compatible
  • gps
  • ufl antenna
See a helpful answer?
sahas
sahas over 10 years ago
I purchased INTERNAL GPS antenna of cooking Hacks for FONA 808 module. the module has a UFl connector on which the antenna fits snugly. Problem is I am able to fix satellite even waiting 30mins
I have tried every where.... Even on the terrace! no signal.
Please suggest.
link of the antenna : https://www.cooking-hacks.com/internal-gps-antenna
Is the antenna compatible? for FONA 808
https://www.adafruit.com/products/2542
    shabaz over 10 years ago in reply to clem57 +1
    Agree. likely there was no examination of the product datasheet if an active antenna was purchased by mistake. And equally unlikely that an antenna could be built and tested with similar levels of examination…
    0 shabaz over 10 years ago
    Probably not.. why didn't you use the recommended one on the adafruit page?
    The adafruit one is passive, whereas the cookinghacks one is active. The latter need a power source (usually inline from the receiver module although with difficulty there are other solutions).
    You'd have to check the adafruit module documentation (or ask adafruit, since they sold it to you) to find out if it supports an active antenna.
  • sahas
    0 sahas over 10 years ago in reply to shabaz
    Is there a way to test it myself? or build one?
    0 shabaz over 10 years ago in reply to sahas
    I saw some examples on the Internet (google for 'make gps antenna').
  • clem57
    0 clem57 over 10 years ago in reply to shabaz
    shabazit strikes me strange why get a good module and not the antenna offered with it?  Cost seems like the problem???
    Clem
    0 shabaz over 10 years ago in reply to clem57
    And equally unlikely that an antenna could be built and tested with similar levels of examination : (
    GPS modules do not have as demanding antenna requirements any more like they used to, and the active one could be used too, but getting the correct parts and solder them will likely be hard for the poster, when instead a more suitable antenna could be purchased.
  • clem57
    No research leads to poor planning and ???
