Ask an Expert Forum Searching for soldering battery pin
  • Answers 2 answers
  • Subscribers 304 subscribers
  • Views 783 views
  • custom battery holder
  • soldering pin
  • connection
  • battery holder
See a helpful answer?
balearicdynamics
balearicdynamics over 9 years ago
Hi to all. I have a problem due my lack of knowledge in the naming (and probably some other knowledge image
I should design a custom battery holder based on a standard type of batteris, formerly the Canon LP-E8 1300 mAh (this is a model link on Amazon: https://www.amazon.es/gp/product/B00IHZ3E8A/ref=oh_aui_detailpage_o02_s01?ie=UTF8&psc=1 )
Unfortunately I have no idea what is the name of this kind of soldering connector but I support that exists...
In attach a detailed explanation of the connectors used in the compatible battery charger
Thank you in advance. Enrico
imageQuickMemo-Canon Battery Connector.pdf
    shabaz over 9 years ago in reply to balearicdynamics +1 verified
    Hi Enrico, Oh, I see. So the battery has the springy pieces, and the charger just has the fixed blades? I'm not sure what could be suitable : ( It could be worth contacting Keystone, they may have something…
    balearicdynamics over 9 years ago in reply to mcb1 +1
    Usually easy answers I try to answer to others Enrico
    0 shabaz over 9 years ago
    Hi Enrico!
    Possibly these types of pins may work: Spring Loaded Contacts & Probes | Farnell element14
    The battery might use custom contacts made for Canon, but if it is just a flat metal contact area then
    the spring-loaded contacts at that link could work.
    0 balearicdynamics over 9 years ago in reply to shabaz
    Hello Shabaz!
    Thank you for your answer. After a couple of hours of tries I have found these contact too, but as far as I know these are sort of cylinders while the battery charger (the official one) holds the batteries with lamellar contacts. It is true that probably these are sort of standard Canon, but as there are lot of Chinese compatible batteries and chargers I expect that these male and female soldering contacts are available on the electronic components market. In few words, just like saying "Philips plug" or similar. I will update the question with a couple of more detailed images now
    Enrico
    Updated the discussion with details. Please take a look to the attached pdf to see what I mean.
    Enrico
    0 shabaz over 9 years ago in reply to balearicdynamics
    Hi Enrico,
    It could be worth contacting Keystone, they may have something appropriate. They do battery
    contacts etc.
    Or if it is low volume, maybe something like this could be bent into a straighter shape with a home-made press/jig for consistency:
    http://www.keyelco.com/category.cfm/9-Volt-Battery-Contacts/For-9V-Cell/p/404/id/422/c_id/956
    0 mcb1 over 9 years ago in reply to shabaz
    I'm thinking the easiest way os tho find a cheap asian sourced supplier, or find some suitable terminals and mould your own.
    They almost appear to be a board to board style connector.
    You do give us the tricky questions.   image
    0 balearicdynamics over 9 years ago in reply to mcb1
    Usually easy answers I try to answer to others image
    Enrico
