Ask an Expert Forum available commands for remote control of power supply 2445412
  • Subscribers 339 subscribers
  • Views 3382 views
  • remote command power supply 2445412
See a helpful answer?
efa200
efa200 over 9 years ago
hi,
on the PDF manual:
http://www.farnell.com/datasheets/1848826.pdf
only: *IDN?
is listed as remote command for the power supply 2445412:
72-2540 TENMA - ALIMENTATORE, 1 CANALE, 30V, 5A, PROG, Farnell element14 Italia
while Software download link:
http://www.farnell.com/software/2058256.zip?_ga=1.99686683.463325991.1473943560
show the following error:
"Sorry, the file you were looking for does not exist on this system or is not available to your site."
Where I can find the complete list of commands?
This just to see what is remotely settable/readable.
I need it to understand if it is suitable as automation for test bench, and to write control software.
thanks
  • rachaelp
    0 rachaelp over 9 years ago
    I did a little searching and this thread here has what looks to be the command protocol specification for this range of power supplies attached:
    https://www.element14.com/community/docs/DOC-75108/l/protocol-information-for-tenma-72-2550-and-tenma-72-2535-qa-window-driver
    Best Regards,
    Rachael
  • efa200
    0 efa200 over 9 years ago in reply to rachaelp
    so documentations for PN:
    72-268572-268572-269072-269072-269572-269572-270072-2700
    72-270572-270572-271072-271072-271572-271572-272072-2720
    is suitable for  72-254072-2540 too
  • rachaelp
    0 rachaelp over 9 years ago in reply to efa200
    I only linked to a thread I found after a very quick search which is relating to the 72-2535 and 72-2550, I don't personally have any of these supplies. However, a little additional googling yields this:
    https://sigrok.org/wiki/Korad_KAxxxxP_series
    It looks like the TENMA power supplies in this range may possibly be rebadged Korad supplies. Anyway, it seems they may all share a common set of SCPI commands so the info you need should be there.
    Best Regards,
    Rachael
