Ask an Expert Forum DIY replacement fan for GPU
  • Subscribers 318 subscribers
  • Views 4199 views
  • cooling_fan
See a helpful answer?
jeppilee
jeppilee over 9 years ago
Hello
My friend has a GPU with a broken fan, i want to replace it with another fan i've scrapped off of an old computer. They are similar in size and type but the plug is different. My question is would it be safe to put connector A unto fan B, and if so, which wires should be matched up?
Thanks.
  • rachaelp
    rachaelp over 9 years ago +1 suggested
    Hi Jeppe, Without seeing the specs for both fans it's not 100% certain which is which but we can probably take some educated guesses. The fans have 4 pins, these are 0V, +12V, Tachometer and PWM, usually…
  • rachaelp
    0 rachaelp over 9 years ago
    Hi Jeppe,
    Without seeing the specs for both fans it's not 100% certain which is which but we can probably take some educated guesses. The fans have 4 pins, these are 0V, +12V, Tachometer and PWM, usually in that order on a PC motherboard. Black will most likely be 0V on both fans. Looking at the position and colours Yellow on the old fan will map to red on the new fan as I believe these will be the +12V. The green from the original fan and yellow for the new will be the Tachometer. Finally this will make both the blues the PWM control. So:
    Old -> New
    Black -> Black
    Yellow -> Red
    Green -> Yellow
    Blue -> Blue
    I did find a reference on the internet with a picture backing this up here: http://www.electronic-products-design.com/geek-area/connectors/pc/fans
    The picture from that page:
    None of what I have said is 100% certain so you need to do your own research too and make sure you are satisfied that these mappings are correct yourself.
    Best Regards,
    Rachael
  • jeppilee
    0 jeppilee over 9 years ago in reply to rachaelp
    Thank you so much for taking the time to reply! I will do some testing and return with my results.
    Jeppe.
  • clem57
    0 clem57 over 9 years ago in reply to jeppilee
    Wiring Color Codes : Color Codes - Electronics Textbook should help
    foxconn pv123812dspf wiring diagram
  • rachaelp
    0 rachaelp over 9 years ago in reply to clem57
    I'm glad you updated to add that second link, I think the first one is in error though as that appears to be for AC or DC power distribution systems.
    From the foxconn link, it appears to back up some of the assumptions I had made above. I did have a quick look for the spec for the original fan and came up with nothing.
