Ask an Expert Forum Question on battery 1298246 Order code
  • Subscribers 326 subscribers
  • Views 409 views
See a helpful answer?
tonyb61
tonyb61 over 9 years ago
This part 1298246 is supposed to be a CR2032 battery with pins to mount on a PCB. The technical data sheet for this part links to a pdf for a CR2032 cell battery with no pins ? Where can I find the correct data sheet ?
Regards
Tony
  • spannerspencer
    0 spannerspencer over 9 years ago
    Ah, it looks like the datasheet is covering a small range of coin cells that have slightly different connector options. But that product listing is for the PCB mount type as pictured.
