Ask an Expert Forum Looking for a tiny projector that can project semi horizontally...
  • Answers 2 answers
  • Subscribers 306 subscribers
  • Views 1097 views
See a helpful answer?
daemonulf
daemonulf over 8 years ago
also some way to split what is being projected between four of said projectors, if someone can help, that'd be nice
thanks
Me
  • beacon_dave
    beacon_dave over 8 years ago in reply to daemonulf +1 suggested
    Smaller than this ? https://www.amazon.co.uk/d/12b/Mileagea-Projector-Miracast-Cinema-Multimedia-Video-Home/B01C2PDKOI/ref=sr_1_24 Here is a typical 1:4 HDMI distribution amplifier KRAMER - VM-4HN - 1…
  • daemonulf
    0 daemonulf over 8 years ago
    so.. no one can help? it's for a project I am making
  • beacon_dave
    0 beacon_dave over 8 years ago in reply to daemonulf
    Your question is a bit vague. What do you mean by tiny ? What do you mean semi horizontally ? Assuming that this is a video projector then what video signal types are you using ?
    You could split video between multiple displays using a 1:4 distribution amp or a projector loop through.
    If you need more control over what parts of the input signal go to which projector then perhaps something like this:
    https://www.datapath.co.uk/multi-display-products/datapath-x4
    However if you are doing projection mapping then these may be of more interest:
    http://www.green-hippo.com/solutions/
    https://troikatronix.com/
  • daemonulf
    0 daemonulf over 8 years ago in reply to beacon_dave
    by tiny I mean as small as possible, and semi horizontally I mean so i could put it in a case at an angle and have it project on to a flat surface, as for the video signal I am going for cheapest but as high quality as possible...i never knew about the 1:4 distribution amp or the projector loop through, thanks for that!
  • beacon_dave
    Smaller than this ?
    KRAMER - VM-4HN - 1:4 4K UHD HDMI Distribution Amplifier | CPC UK
  • daemonulf
    that may work..but i wonder how much space is in the case, I mean I know I'd have to get one to find out, but it would be good to know..I want to add Raspberry Pi or something similar and maybe some way to turn four of them into a touch screen type device..
