Ask an Expert Forum copy and restoring the flash memory in TI CCS and TMSF28376D
  • Subscribers 338 subscribers
  • Views 1306 views
  • code composer studio
  • frontpage
  • ccs7.0.0
  • programing ti microcontroller flash memory
  • ti tmsf28376d
See a helpful answer?
najjarl
najjarl over 9 years ago
Hi
i inherited a complex code project in TI CCS and the verify fails  to compare with the hex code we have as release.
1) can i dump the flash memory to a file and program it back later? would that  work? i have working board and i want the option to  program it back in case the code i have does not work?
how to program flash from the dumped file? not from a hex file?
2) is there a utility to change the memory dump to a hex file?
3)  is there source code in C/C++ that  works with hex files?
thanks,
~loai
tools are CSS 7.0.0 and emulator
  • clem57
    0 clem57 over 9 years ago
    There is a method to flash a program , but they must be hex...
    UniFlash
    UniFlash for Cloud provides a lightweight method to load target programs to internal flash on a wide range of TI devices. UniFlash and CCS Cloud use the same underlying TI Cloud Agent to provide access to your locally connected TI devices and LaunchPads.
    Both a desktop and command line version of UniFlash is also available for the situations where internet access is not available or where a GUI is not needed.
