Ask an Expert Forum accessing register of i2c module in am335x on linux
  • Subscribers 315 subscribers
  • Views 782 views
  • am335x sitara
  • am335xsitara
  • am335
  • am335x
  • am3352
See a helpful answer?
jatinjain12
jatinjain12 over 8 years ago
Hello everyone,
I am using a board having am335x mcu on it. i am using linux operation system on it. I want to know that how can i access i2c registers of am335x..?
Regards
Jatin
    shabaz over 8 years ago +1
    Hi Jatin, This isn't an mcu, it is a processor with memory management. There typically isn't direct access to the registers from user applications once Linux is running, so you need to rely on drivers…
    0 shabaz over 8 years ago
    Hi Jatin,
    This isn't an mcu, it is a processor with memory management. There typically isn't direct access to the registers from user applications once Linux is running, so you need to rely on drivers.
    If you search for 'beaglebone i2c' you'll find examples in many languages on how to access I2C. For example using Python or C. Some notes on using C are here: BBB - I2C notes
  • jatinjain12
    0 jatinjain12 over 8 years ago in reply to shabaz
    Hi Shabaz,
    Thanks for your help. Actually i want to change the frequency of I2C on run time that is why i want to access I2C registers. Can you suggest some way to achieve the same..?
    Thanks and Regards
