Ask an Expert Forum LCR film capacitor FSC/EX120pF 1% 630V
  • Replies 8 replies
  • Subscribers 312 subscribers
  • Views 913 views
See a helpful answer?
leekingsee
leekingsee over 8 years ago
A film capacitor I bought from Elements 14 (LCR FSC/EX120 pF 1% 630V - Elements order no. 952-0678) has a blue band at one end of the capacitor.  What does this indicate? Polarity (for a film capacitor) or any special precautions to take in soldering? Kindly advise.
  • rachaelp
    rachaelp over 8 years ago +1
    It's not stated in the data sheet and I haven't spent any time digging into these specific capacitors any further but I suspect it may be something along the lines of marking the outside jacket side of…
  • rachaelp
    rachaelp over 8 years ago in reply to rachaelp +1
    And to back up what's said in the video above, here is another website which talks about why there is a band end on some non-electrolytic capacitors: http://www.aikenamps.com/index.php/where-to-connect…
    jw0752 over 8 years ago in reply to rachaelp +1
    Hi Rachael, 50 years ago when a lot of the capacitors were foil wrapped the line was put on one end to indicate the outer foil. This allowed the capacitor, if used for decoupling, to be orientated so that…
  • rachaelp
    0 rachaelp over 8 years ago
    It's not stated in the data sheet and I haven't spent any time digging into these specific capacitors any further but I suspect it may be something along the lines of marking the outside jacket side of the aluminium foil electrodes. There is a very informative YouTube video by a gentleman called Mr Carlson who explains this very well:
  • rachaelp
    0 rachaelp over 8 years ago in reply to rachaelp
    And to back up what's said in the video above, here is another website which talks about why there is a band end on some non-electrolytic capacitors: http://www.aikenamps.com/index.php/where-to-connect-the-outside-foil-on-capacitors
    Best Regards,
    Rachael
    0 jw0752 over 8 years ago in reply to rachaelp
    Hi Rachael,
    50 years ago when a lot of the capacitors were foil wrapped the line was put on one end to indicate the outer foil. This allowed the capacitor, if used for decoupling, to be orientated so that a degree of shielding was afforded and EMI was minimized.
  • rachaelp
    0 rachaelp over 8 years ago in reply to jw0752
    John Wiltrout wrote:
    Hi Rachael,
    Yes agreed, and I guess 50 years ago it was more common knowledge amongst engineers, but a lot of people don't ever use these styles of capacitor anymore so this is something that for a lot of people just isn't well known. Fortunately there are still a few people around who know things like this image
  • leekingsee
    0 leekingsee over 8 years ago
    Dear Rachael and John,
    Thank you so much for helping me to understand more about this subject.  It is a pity I don't possess the necessary equipment to carry out the tests.
    Kindest regards
    King
  • rachaelp
    0 rachaelp over 8 years ago in reply to leekingsee
    Hi King,
    Fortunately as your capacitors have the bands which indicate the outer foil end you don't need any equipment to test these. Just follow the tips in the video or on the website I linked to correctly orient the capacitors if that is appropriate for your application.
    Best Regards,
    Rachael
  • leekingsee
    0 leekingsee over 8 years ago in reply to leekingsee
    Grateful thanks again, Rachael.
    King
  • rachaelp
    You're welcome image
