Ask an Expert Forum Printed circuit board failure
  • Replies 40 replies
  • Answers 18 answers
  • Subscribers 346 subscribers
  • Views 10769 views
See a helpful answer?
bd467
bd467 over 9 years ago
I have a miller welder that blew some resistors and a voltage regulator on 2 boards. I can buy new boards but that's around $2,000. the resistors are burnt to the point I don't know what size they are. I've tried contacting Miller Electric but they told me they can't send me any info on the boards. Can anyone help me with this? I don't know a lot about electronics. Part numbers for the two boards are 207818 PC2 and 200841 PC10. imageimage
    dougw over 9 years ago +5 suggested
    The damage in the bottom picture to the resistor and Q11 are not from a little gentle overload - they look like massive catastrophic overload - as in perhaps mains voltage got shorted across them. Simply…
    jw0752 over 9 years ago +4 suggested
    Hi Billy. If you know anyone else with one of these units perhaps they would give you a quick look so you could note the color bands on their resistors. Other than that, like dougw said there are going…
    dougw over 9 years ago in reply to bd467 +4 suggested
    The damage on Q11 probably caused that noise. Thermal expansion stress due to very rapid localized increase in temperature (as a result of excessive current) causes the chip package to explode. The onset…
  • EHamid
    0 EHamid over 4 years ago
    bonjour à tous
    R6 = 100K ohm
    R7 = ????
    merci
  • EHamid
    0 EHamid over 4 years ago in reply to bd467
    bonjour
    moi aussi j'ai le meme problème et je cherche la valeure de R7
    merci
  • lanuser
    0 lanuser over 4 years ago in reply to EHamid
    R6: 20 KΩ ±1%            For ASSEMBLY NO. 200841
    R7: 1.5 KΩ ±1%           For ASSEMBLY NO. 200841
  • EHamid
    0 EHamid over 4 years ago in reply to lanuser
    Bonjour lanuser
    Merci pour votre réponse
    • Moi je cherche la valeur de R7 = ??  pour assembly 247321A
  • lanuser
    EHamid,
    I don't have schematic for ASSY NO: 247321A   ( strange when full production manufacturer using  "A" on the end.   A = Alpha? )
    However, this looks like primary 3V circuit start portion on power on, seems similar to ASSY NO: 200841 The Item Has changed to ASSY NO: 230170
    Use R7: 1.5 KΩ ±1% ( at your own risk ) but I am about 99.9% will work.
    Also check Main Power Distribution board D4 & Q2 & Q11 for short or open.
     Please provide feed back if your unit restored.
    Thank you and good luck.
  • EHamid
    thank you very mutch for your help , my friend you are very gentle Handshake tone2Palm tree
  • BrooksCircuit
    0 BrooksCircuit over 4 years ago in reply to lanuser
    For the main power board, what is the p/n for D4? I wrote it down, but messed it up somehow. I wrote STTHB12DT. No idea what I was thinking . . . I believe it is used in a buck supply with IRF640N. So I guess I could just match the FET in V and A . . . What do you have for R6 value on the Power Dist board? Looks like lines were getting crossed above between R6 on two different boards
  • lanuser
    0 lanuser over 4 years ago in reply to BrooksCircuit
    Do you got pic where D4 on the board located?
    Better yet provide board ASSY NO:
  • BrooksCircuit
  • lanuser
    My Board # LD-28
    D4 = STTA812DI ( OBSOLETE ) ( cross reference on DigiKey ) Verify : www.newark.com/.../58K9522
    R6 = 0.18 Ω  1/2W ( replace with wire wind resistor )
    Just to be on same page ( my color of resistor slight off do to age, however, my old 77IIIFLUKE shows under 1 Ohm )
    Please let me know if your unit got back to life.
    Thanks and good luck.
