Ask an Expert Forum PR261-1 Snapped off on installation
  • Subscribers 337 subscribers
  • Views 669 views
  • spring loaded contacts & probes (54)
See a helpful answer?
wires1
wires1 over 8 years ago
Hi
Just building a test jig and soldered the wires to 17 of the  PR261-1PR261-1 using heat sinks to prevent melting the mounting block
  • Spring Loaded Contacts & Probes (54)
When I inverted the mounting block to fit it into the holder 4 of the bodies snapped off.
There appears to be a weakness in the body where there is a depression around the circumference.
Has this happened to anyone else using these spring loaded contacts?
Please see attached picture.
    jw0752 over 8 years ago +2
    Hi Lee, I have been thinking about how the pins failed for your application. While I do not have any experience with these pins it seems to me that you could repair them by taking a small section of brass…
  • 14rhb
    14rhb over 8 years ago +1
    Lee, That's strange - I would have thought they were more robust than that. Perhaps contact the manufacturer to see what they think? From the pdf datasheet: Ostby Barton A Division of Everett Charles Technologies…
  • wires1
    wires1 over 8 years ago in reply to jw0752 +1
    Hi John Thank you for the idea but I have now replaced them with physically larger spring terminals and that has worked out OK. Now I have to make up a holder to position the boards over and also push…
    0 jw0752 over 8 years ago
    Hi Lee,
    I have been thinking about how the pins failed for your application. While I do not have any experience with these pins it seems to me that you could repair them by taking a small section of brass tubing and use it as a sheath to couple the two broken pieces. It it were soldered in place it would make a good repair. Since you know where the weakness is now you could preemptively put sheaths on the pins.  Another help might be to find a way to put strain reliefs on the wires before they attach to the pins. By the way I was impressed with the beautiful connector that you made and the excellent solder job.
  • 14rhb
    0 14rhb over 8 years ago
    Lee,
    Ostby Barton
    487 Jefferson Boulevard
    Warwick, RI 02886
    Tel: (401) 739-7310
    Fax: (401) 732-4937
    www.ectinfo.com
  • wires1
    0 wires1 over 8 years ago in reply to jw0752
    Hi John
    Thank you for the idea but I have now replaced them with physically larger spring terminals and that has worked out OK.  Now I have to make up a holder to position the boards over and also push it into contact with the 'nails'.
    These (larger) terminals are only rated at 1amp - so we will see how we go when testing begins.
  • wires1
    0 wires1 over 8 years ago in reply to 14rhb
    Thank you Ostby - I will contact them.
    Lee
