Ask an Expert Forum Home automation
  • Replies 13 replies
  • Subscribers 337 subscribers
  • Views 3291 views
  • wifi
  • home automation
See a helpful answer?
Home automation
mads391i
mads391i over 8 years ago
Hi
Element community
I'm thinking about making some home automation. I just stared planning stuff in my head, but came over a question I probalbly need some help with. I was think about making the system over Ethernet, but the more i thought about i started to think it would be smarter making it WiFi. Maybe even blue tooth, but mostly WiFi.
What is the pros n cons about making it WiFi?
    michaelkellett over 8 years ago +1
    Shabaz posted a blog on this subject but RPi based - I suggest you look at that. MK
  • colporteur
    colporteur over 3 years ago +1
    What do you wish to automate?
  • kmikemoo
    kmikemoo over 3 years ago in reply to shabaz +1
    I sometimes wonder why these resurface on the main landing page without any new comments.
    0 michaelkellett over 8 years ago
  • yadhu22krish@gmail.com
    0 yadhu22krish@gmail.com over 8 years ago
    Hi Mads....
    Each one has its own pros and cons....If you are looking for some Relays and Gpio modules whether it is ethernet or wifi or usb , you can find it here.
    https://numato.com/product-category/automation
  • brynjar.e
    0 brynjar.e over 8 years ago
    Wifi is cheap and has usually a longer rang then Bluetooth, also you can setup a page hosted by the WIFI module like esp8266. And connect to it with all devices connected to your network. Also its possible to setup a remote connection and connect to it anywhere in the world as long as you have internet, and if you have a Bluetooth module you have to make an app to control everything. While a wifi module can host a HTTP page with websocket.
    If you are intrastate in using a wifi module I would recommend you check out CNLohr on youtube
    0 e14 Contributor over 3 years ago
    [deleted]
    0 shabaz over 3 years ago in reply to e14 Contributor
    Spam, reported
    0 dougw over 3 years ago
    There is no reason why you need only one communication technology, these can all work together. The choice of technology can be dictated by what is best for the particular function you are automating.
    Some Pros and cons of Wi-Fi
    Pros
    • wireless - don't need to string wires
    • easy to interface to the wider internet
    • high bandwidth - you can send video
    • can work with your smart phone
    • lots of products and software available
    Cons
    • not the lowest cost for some applications
    • not the lowest power consumption for some applications - probably need mains power
    • Wi-Fi is microwave radiation - not healthy for people
    • it can be hacked - need to consider security
  • colporteur
    0 colporteur over 3 years ago
    0 shabaz over 3 years ago in reply to colporteur
    This discussion's about a decade old from memory! : ) The requirement from the original poster may have gone away by now.
  • kmikemoo
    0 kmikemoo over 3 years ago in reply to shabaz
    0 dougw over 3 years ago in reply to kmikemoo
    Maybe somebody checking to see who is awake... clearly I wasn't awake Zzz...
