Ask an Expert Forum Messing with a Sanyo DMP-600 MP3 Player
  • Replies 8 replies
  • Answers 3 answers
  • Subscribers 308 subscribers
  • Views 1750 views
  • mod
  • hack
  • dmp-600
  • sanyo
  • mp3 player
See a helpful answer?
vamptonius
vamptonius over 8 years ago
I've had this device since it came out and I love it, a little too much if the cracks in the corner of the case are anything to go by.  And it died when the battery refused to charge (mainly because it's gone the way of Lithium Ion Polymer Batteries and puffed up).  So I opened it up to try and replace the offending cell and managed to defeat the glue and unplug it and now it works like a memory stick in my computer, but nothing else.  But I'm unsure what to replace the failed battery with.  It's a 3.7 volt but refuses to mention the amperage, or current so I don't know what to buy and can't find out anything online.  You wouldn't believe how hard it was to even find the attached Service Manual.
And it's sitting here in pieces anyway.... what if I boost the memory from it's functional 487Mb by adding a USB or Micro SD?  Or up the power capacity for longer times between charges?  Could I fiddle with the internal software to increase the recording fidelity (Radio & Voice) from it's current 128kbps MP3 to something more like 320, or FLAC, or both?  What about designing and printing a new case?  And how would I go about achieving all or any of this without resources (though I could probably find somewhere local for the printing as my library did a 3D printing thing a while back and probably still has it knocking around), or skills needed.  I did a little electronics course, (WOW!) 24 years ago but I remember almost nothing from it.
At the very least, I'd like to not fry it by getting the wrong replacement battery.
Any thoughts or advice?
imagedmp-m600_sm.pdf
  • gam3t3ch
    gam3t3ch over 8 years ago in reply to vamptonius +2 suggested
    https://www.alibaba.com/product-detail/3-7V-450mah-431575-Rechargeable-lithium_60619746158.html?spm=a2700.7724857.main07… That is the only one I could find that size well roughly what you measured.
  • vamptonius
    vamptonius over 8 years ago +1
    I'm not sure how the question ended up being aimed at the very busy Mr. Heckendorn, but I couldn't publish it without putting something in the box at the bottom and it suggested it.
  • gam3t3ch
    gam3t3ch over 8 years ago in reply to kk99 +1
    I want to say most where 3.7V 1500 Ma lithium battery I owned a ton of different ones back in the day and that was standard in most. headphones draw 20mw, USB charge for PC approx. 2 hr.Battery life (playback…
  • vamptonius
    0 vamptonius over 8 years ago
  • kk99
    0 kk99 over 8 years ago
    Could you measure dimensions of battery ? Are you sure that there is no information e.g. about capacity on battery ?
  • gam3t3ch
    0 gam3t3ch over 8 years ago in reply to kk99
    I want to say most where 3.7V 1500 Ma lithium battery  I owned a ton of different ones back in the day and that was standard in most.  headphones draw 20mw, USB charge for PC approx. 2 hr.Battery life (playback): 10 hours    and this is where my brain says it needs the white board for mathing so not happening tonight but I would think  just looking at those numbers it may have been a smaller one 850ma battery but I could be far off on this. but sounds somewhere in there.
  • vamptonius
    It measures out at 74mm x 12mm x 4mm when you squeeze it back to it's original thickness.  The bar-code on the back reads "+421275 639536102686"
  • vamptonius
    And thank you all.
  • gam3t3ch
    0 gam3t3ch over 8 years ago in reply to vamptonius
  • vamptonius
    So, with luck that answers my power problem, (the company only sells in boxes of 50 and I'm not sure what the connection is as it's not shown.  But I'm in negotiation).  But what about modding options?  Is anything possible based on that document, or would I need to upload close up's of the circuitry?
  • kk99
    0 kk99 over 8 years ago in reply to vamptonius
    It will be nice if you could upload photo of the PCB part related to charging circuit. Probably old battery have similar capacity so you no need to modify circuit. The safest charge rate for most LiPo batteries is 1C, so for this new battery it will be 450 mAh.
