Ask an Expert Forum Old Tech Help Needed - Siemens NotePhone
  • Subscribers 325 subscribers
  • Views 931 views
  • frontpage
See a helpful answer?
sonnyny
sonnyny over 8 years ago
Greetings Everyone,
So joined the Element14 Community after running across a YouTube video from The Ben Heck Show about the Nintendo Playstation prototype Repair. I'm hoping that someone here or hopefully local to me could lend me their expertise in trouble shooting my Siemens NotePhone.
So here is a set of photos of my Siemens NotePhone on my Flickr Stream.
https://www.flickr.com/photos/sonnyhung/albums/72057594059547504
This is a 3rd Party Newton OS device that has a Modem and a Telephone Base when fully connected together.
This particular Newton main unit is not the standard German Newton OS. It has had its MLB transplanted from a US Newton OS MLB.
The Newton itself works find.
The Modem portion I'm unsure of, but expect it to be working also.
The Telephone Base for the most part works.
I've tested it out and fabricated a US Telephone Cable and checked that it works.
The ISSUE however is that the Telephone Base is having issues with the Handset Hook. If you leave the unit plugged in with handset down in the cradle it will sense the phone as hung up.
Unfortunately after awhile it thinks that the handset is picked up and after a longer time frame the telephone thinks it's busy with the Busy Sound.
That's the best way I can describe it.
What I'm looking for is someone to troubleshoot this so this unit can be connected and used as a telephone.
If anyone near me can do this let me know.
There are not schematics and I have a picture of the MLB (bottom).
https://www.flickr.com/photos/sonnyhung/224611394/in/album-72057594059547504/
I've contacted a few local electronics repair establishments but they are unwilling to help me with this.
I'm assuming one of the electronics is bad as I was told this happens to most units my friend has seen so far and non are exempt from this problem.
Thanks for any help you can provide. I'm willing to test myself and repair, but understand I don't have any electronics background.
I'm ex-IT laptop support specialist, so I can troubleshoot basic hardware issues but not the detailed electronics issues.
  • jdlui
    0 jdlui over 8 years ago
    Not sure if I fully understand your problem: The handset hook is the sensor that pushed down when you place handset on the unit?
    How does the sensor look from the inside, and how does it connect to the PCB? Maybe do connectivity tests on the leads as you push the hook down?
  • sonnyny
    0 sonnyny over 8 years ago in reply to jdlui
    Thank you for your reply.
    Yes, I would agree that these sir that detects the handset is seated down in the cradle is the likely culprit. How do I test to confirm this?
    What I was told is that if the base unit is put in the freezer and then take out and put together that when the unit warms up the issue rears it’s ugly head.
    So how do I trace this to confirm where the issue is?
    I think in one of my close up photos of the MLB I have highlighted a small square where I think is the contacts for the switch for the handset when it is down on the cradle. How do I test this?
    Sonny Hung
    Sent from my iPhone 
  • swampyank1
    0 swampyank1 over 8 years ago
    Hello Sonny Hung;
    I happen to work for a company that makes a phone for schools. They for parking lots to get help from the PD or FP, when in trouble.
    I have seen a couple of time by switching the TIP and RING weirs that type of problem will or should go away.
  • rsc
    0 rsc over 8 years ago
    You may have to add some resistance in-line to be < 5 REN
    1 REN as equivalent to a 6930 Ω resistor in series with an 8 µF (microfarad) capacitor.
    https://en.wikipedia.org/wiki/Ringer_equivalence_number
    Scott
