Ask an Expert Forum 18650CA-1S-3J Battery "Specified Charger"
  • Subscribers 326 subscribers
  • Views 676 views
  • battery charging
  • battery
  • lithium-ionbattery
See a helpful answer?
rpike
rpike over 8 years ago
I've purchased the above battery to test it's viability for a product my company is designing. 18650CA-1S-3J BAK, Rechargeable Battery, 3.7 V, Lithium Ion, 2.25 Ah, Connector, 18.5 mm | Farnell UK
On the outside of the battery there's a label which states: "Use specified charger only". I can't locate this specified charger anywhere on the datasheet or anywhere online, only acceptable specifications for charging. Has anyone located the specified charger?
Has anyone used this battery in their own design? Did you use an off the shelf charger or embed your own charging circuitry into the design?
Richard.
  • koudelad
    koudelad over 8 years ago +3 suggested
    Hello, I think you have answered your own question. The datasheet states charging specification, so a specified charger is one that follows the rules. If you are building a prototype or some home-grown…
  • koudelad
    0 koudelad over 8 years ago
    If you are building a prototype or some home-grown device you can use a ready made module like these:
    https://www.adafruit.com/product/1304
    https://www.adafruit.com/product/390
    If you are designing a final product, it is better (smaller, cheaper, ...) to embed the circuitry on your PCB with the consuming circuitry.
    David
