Ask an Expert Forum Electronic components in Fusion 360
  • Subscribers 330 subscribers
  • Views 1821 views
  • dxf
  • Design Center
  • mesh
  • fusion 360 newbie
See a helpful answer?
ajkatz83
ajkatz83 over 8 years ago
Hey all:
My question is how would one go about importing non-industrial components into Fusion 360? I have seen the options to insert from a manufacturer and basically I am not going so much that route as I'm more of a hobbyist here. I understand that meshes or even SXF or DXF files can be imported in, which I have tested and understand how to do, the next part I suppose would be how to scale those files to the project being worked and where is there a good  repository of (I'm guessing) DXF files? I just noticed this now in Fusion 360 and it would have been good to have used in the project I was working on, especially with the joystick that was in the design.
  • kakrona
    0 kakrona over 8 years ago
    Interested in this case
  • klimbo13
    0 klimbo13 over 7 years ago in reply to kakrona
    I am currently using http://www.mcmaster.com/ for importing 3D STEP files for screws and nails. I was wondering where I could find a similar site for electronic components, specifically LCD screens, RAM and other hardware componenets? I would like to ultimaltey import these components into my project.. even see: Bluestacks TextNow Photomath .
  • rusgray
    0 rusgray over 7 years ago
    The easiest way to do this is to use Autodesk's EAGLE software package. There's a built-in function to coordinate between the two packages for design purposes; you can choose to have either program be the 'master' for a given project, so you can have the mechanical/enclosure design drive the PCB design, or vice versa.
    EAGLE also has a built-in package generator that will make footprints and 3D models for many common parts based on data sheet dimensions. For parts you can't (or don't want to) make with EAGLE's package editor, you can try https://www.ultralibrarian.com. If you can't find it there, try the manufacturer's website. If that fails, try https://www.3dcontentcentral.com/
