Ask an Expert Forum How to use a 7.4v 2S LiPo with integrated charging for my project?
  • Answers 2 answers
  • Subscribers 338 subscribers
  • Views 3593 views
  • charging
  • usb charging
  • robot
  • battery
  • lipo_charger
  • lipo
See a helpful answer?
darthmarshie
darthmarshie over 7 years ago
How would I go about including a 7.4v 2S LiPo battery with integrated charging in my project? The ideal situation for me would be to have the battery and charging in the project so that I could just connect a USB or barrel jack connector for charging without having to remove the battery to charge it.
This is the sort of battery I had in mind:
I just can't seem to find any sort of PCB solution to charging batteries like this. I can only find boards that charge 3.7v single-cell LiPo batteries. Like this:
The other thing I have found is boards like this:
https://www.banggood.com/2S-Li-ion-18650-Lithium-Battery-Charger-Protection-Board-p-1216133.html?rmmds=home-mid-relatedViewed&cur_warehouse=CN
But that seems to only be a protection board for 18650 Li-Ion cells and doesn't actually appear to be for charging the batteries.
If I were to use a 2S protection board like that, would I just connect the centre terminal of the balance plug to the MB terminal on the board? How would I then go about actually charging up the batteries?
Any help would be appreciated.
  • Robert Peter Oakes
    Robert Peter Oakes over 7 years ago in reply to dougw +2
    Be Careful, that one is a Charing module, not a Charging module, perhaps it is used to destructively test batteries
    Robert Peter Oakes over 7 years ago in reply to dougw +2 suggested
    On a more serious note though this one or similar is easy to find and cheap, adds the benefit of balance protection etc https://www.aliexpress.com/item/2S-6-4V-10A-Lithium-Ion-Phosphate-Battery-Protection…
    dougw over 7 years ago +1 suggested
    These charging modules are available on-line for about $2: You have to solder a short between the 2 pads to charge 7.4 V. And the input voltage needs to be higher.
    0 dougw over 7 years ago
    0 Robert Peter Oakes over 7 years ago in reply to dougw
    Be Careful, that one is a Charing module, not a Charging module, perhaps it is used to destructively test batteries image
    https://www.aliexpress.com/item/2S-6-4V-10A-Lithium-Ion-Phosphate-Battery-Protection-Board-Charger-Discharger-with-Balan…
