Ask an Expert Forum Third Party Operating System doesn't work once Raspbian is used in raspberry pi
  • Subscribers 316 subscribers
  • Views 359 views
See a helpful answer?
anupsaxena
anupsaxena over 7 years ago
Hi
I would like to ask whether a third party OS i.e. ubuntu mate can run if the pi had previously been running rasbian. I had installed ubuntu mate in a new memory card. when it is inserted to pi which had raspbian as its OS it doesn't respond but when the same memory card is inserted in a system running ubuntu mate it works.
    shabaz over 7 years ago +1
    anupsaxena wrote: ... can run if the pi had previously been running rasbian Hi Anup, Once the Pi is powered off and micro SD removed, it behaves at a high-level like a new Pi. Therefore, if you remove…
    0 shabaz over 7 years ago
    anupsaxena  wrote:
    ...can run if the pi had previously been running rasbian
    Hi Anup,
    Once the Pi is powered off and micro SD removed, it behaves at a high-level like a new Pi. Therefore, if you remove the microSD containing Raspbian, you are free to install a microSD card containing a different OS, just like as if you'd purchased a new Pi.
    I'm not sure what could be the issue, but if you're interchanging cards from one Pi to another, you may hit some situations where some OS may hang during startup, in some cases for periods of time longer than expected, since you've changed hardware identifiers (e.g. burned-in MAC addresses) under the feet of the OS.
