i have connected 8 servo motor to BBB but when i run python script it give error
(power failure system halt error occurs and board get rest )
What are you using to power the servo motors? What are you using to power the BBB? Are you using a USB cable? USB only provides 0.5 amps. Did you power it using the 5 volt barrel connector? Use a 2 amp or 3 amp 5 volt power supply with the barrel connector.
