Ask an Expert Forum Vishay 10nF 'Snubber' Caps
  • Subscribers 314 subscribers
  • Views 655 views
See a helpful answer?
bazgowan
bazgowan over 6 years ago
Hi, I just bought a small supply of these (Mfg P/N: KP1830310251 ) for a 'snubber' application with dual schottky diodes in a rectifier bridge configuration. Please can you tell me if they are 'bipolar', types?(That is, NO image or image leads)
So it doesn't matter which way round to solder them?
Or..?
  • Gough Lui
    Gough Lui over 6 years ago +1 suggested
    They are polypropylene capacitors, so they should be insensitive to polarity in much the same way as polyester or ceramic capacitors are. These belong to a class of capacitors known as film capacitors…
  • Andrew J
    0 Andrew J over 6 years ago
    You’re probably best asking Vishay themselves:
    For technical questions, contact: dc-film@vishay.com
  • Gough Lui
    0 Gough Lui over 6 years ago
    They are polypropylene capacitors, so they should be insensitive to polarity in much the same way as polyester or ceramic capacitors are. These belong to a class of capacitors known as film capacitors, which are generally not polarised.
    For polarity sensitive through-hole capacitors, they will be marked clearly on the package as to which connection is positive or negative (usually on the case) and one of the legs (the positive one) is longer.
    - Gough
