Ask an Expert Forum Capacitor code on Bose AWRCC5 radio CD
  • Subscribers 338 subscribers
  • Views 1921 views
See a helpful answer?
mousermagyar
mousermagyar over 6 years ago
Hi, can anyone out there assist. I am repairing a Bose Wave Radio from 1994 which has a  problem capacitor. It's a surface mount aluminium radial with the code v bar (bar is on top of the v) then 2; the next line reads 100 and the third line 6V. Can anyone help me identify this?
Barry
    jw0752 over 6 years ago +6 suggested
    Hi Barry, It would help to see a picture but what you describe sounds like 100 uF at 6 volts DC. Most of the time aluminum capacitors are rated in Micro Farads and the 6 volts is a low but not uncommon…
    0 jw0752 over 6 years ago
    Hi Barry,
    It would help to see a picture but what you describe sounds like 100 uF at 6 volts DC. Most of the time aluminum capacitors are rated in Micro Farads and the 6 volts is a low but not uncommon voltage rating.
    • Vote Up +6 Vote Down
  • daviddavid
    0 daviddavid over 3 years ago in reply to jw0752
    Radial Electrolytic Capacitor, 100uF, 6.3uA, 6.3V, 175mA, Panasonic
    can that be good instead of the aluminum ?8image
    CAN THE
    BE GOOD INSTEAD?
  • daviddavid
    Hi Barry can you give a link for Capacitor?
