Ask an Expert Forum Flux missing in Cored Solder Wire - Possible Solutions?
  • Subscribers 304 subscribers
  • Views 571 views
  • soldering tips
  • rosin flux
  • soldering paste flux
See a helpful answer?
indiangeek
indiangeek over 5 years ago
     While soldering, a common issue that I sometimes face is that the cored solder wire that I use, sometimes comes without flux inside the core. Like the core is empty.
     Now of course,this is an issue as no flux could result in bad soldering welds, and other problems in general, and also the problem cannot be diagnosed without using the solder wire itself.
     I was wondering if anyone over here faces the same issue, and if so, do you have any tips/methods that you use to diagnose these "bad wires"..??
Thanks image image image
  • Gough Lui
    Gough Lui over 5 years ago +1
    Invest in better quality multi-core solder wire if you can. Never had an issue with flux consistency with better brands (e.g. Multicore, Kester, etc ) ... If not, you could also look at the flux dispensing…
    0 dougw over 5 years ago
    There are lots of times when more flux comes in handy.
    I keep a syringe of flux around for such occasions.
  • Gough Lui
    0 Gough Lui over 5 years ago
    If not, you could also look at the flux dispensing pens that are like a marker pen and draw over the connections before you pick up the iron and add solder.
    - Gough
