Ask an Expert Forum SD card imaging utility?
  • Replies 13 replies
  • Answers 11 answers
  • Subscribers 302 subscribers
  • Views 1910 views
  • imager
  • sdcard
See a helpful answer?
embeddedguy
embeddedguy over 5 years ago
Hi Friends,
I have a lot of Sd card and usually nowadays find it difficult to either formate or manage SD cards to write a new image for RaspberryPi. Anyone else also struggle to do that? Do you have any recommendations for tools?
    shabaz over 5 years ago +2 suggested
    Hi Ujjval, Problems might be very possible with poor quality (or fake capacity) SD cards. I only purchase good brands from a reputable seller and have had 100% success forever. There's no detail so perhaps…
  • cstanton
    cstanton over 5 years ago +2 suggested
    Linux: Grab an SDCard, ideally larger than 8gByte Download the Raspbian image from raspberrypi.org, you then have to extract the image from the archive because it is usually in a .zip file, this means…
  • Gough Lui
    Gough Lui over 5 years ago in reply to cstanton +2 suggested
    Actually dd can be as fast as any other tool - the problem is by default, it copies using a block size that is much too small (probably just 512 bytes) adding a lot of CPU overhead. Adding a larger block…
    0 shabaz over 5 years ago
    Hi Ujjval,
    Problems might be very possible with poor quality (or fake capacity) SD cards. I only purchase good brands from a reputable seller and have had 100% success forever. There's no detail so perhaps you're following incorrect instructions or maybe you have a faulty download, or downloading from a strange source.
    Beyond that, I don't think there is anything wrong with the instructions at https://projects.raspberrypi.org/en/projects/raspberry-pi-setting-up/2
    Personally I still use an earlier piece of software called Win32DiskImager because it works fine for me. If you're struggling, it is best to stick to the official raspberrypi.org instructions to the letter, since tens of thousands of people will have followed those instructions, and if there was an issue with their instructions they ought to know about it very quickly.
  • embeddedguy
    0 embeddedguy over 5 years ago in reply to shabaz
    I have 3 SD cards, two are from Samsung and one Sandisk. As I posted in one of my road test reviews about RPI last year I will again say it.
    I also have genuine downloads from the official website etc so that should not be a problem.
    In fact, the instructions at Raspberrypi's website are always good and easy to follow, As I am using Linux could be that I am facing hard times with sd cards. FYI, I have tried belenaetcher, RPI official imager, Diskparted, linux's inbuilt tools to formate the sd cards, but none of them worked properly, Yes Unfortunetely. I will give a try to dd tool now.
    0 shabaz over 5 years ago in reply to embeddedguy
    embeddedguy  wrote:
    ..As I am using Linux could be that I am facing hard times...
    You left that piece of important information out of your question.
    Unfortunately, you're going to find it harder to get as much best practice information simply because you're using a very uncommon desktop OS. Most of the Pi setup related information out there will be assuming Windows or Mac.
    The raspberrypi.org instructions are for children, and it is really unexpected for them to be running Linux on a PC, let alone most adults.
    I think if you're doing something advanced like running Linux on your desktop then you have to be prepared to dig deeper, and debug a little harder.
    Your issue could be anything - could even be a driver issue.
    Raspberrypi.org actually do have information for Ubuntu - they picked one of the more popular Linux distributions for beginners.
    I cannot help you much further because I don't have much experience with desktop related issues such as SD card imaging.
    Once you have figured it out, please write it up in a blog post to help other Linux users.
    More generally, if you're having Linux issues, you should also try to join a Linux user group.. people have plenty of advice to share, and there are sometimes Linux virtual classes.
  • cstanton
    0 cstanton over 5 years ago
    Linux:
    1. Grab an SDCard, ideally larger than 8gByte
    2. Download the Raspbian image from raspberrypi.org, you then have to extract the image from the archive because it is usually in a .zip file, this means you'll usually have to install 'unzip' using your package manager
    3. Insert your SDCard, find its mount point, typically dmesg will tell you (for example, /dev/sdb0)
    4. use dd to write the image to the SDCard
    A couple of steps here that catch you out typically:
    • Your user may not have the correct privileges to do this, you may have to elevate your privileges via superuser (sudo)
    • The SDCard you're using might not have enough space, 8gByte SDCard and an 8gByte image may not match up properly
    • SDCard you're using might be damaged, usually the default failure mode is that they go into 'read only' mode
    • dd can be slow, there are ways to do this faster, stack overflow has good tips for this, as does searching on google.
  • Gough Lui
    0 Gough Lui over 5 years ago in reply to cstanton
    Actually dd can be as fast as any other tool - the problem is by default, it copies using a block size that is much too small (probably just 512 bytes) adding a lot of CPU overhead. Adding a larger block size argument will make things faster, if not equally fast, as most other solutions - e.g. "bs=8M" for an 8MByte block size. So instead of using 'dd if=image.img of=/dev/sdx', you would use 'dd if=image.img of=/dev/sdx bs=8M'. Try it yourself and see the difference! It is by far the easiest way to do things on Linux, but be doubly sure you have the right devices or you could end up with data destroyer instead ... the other nickname for dd. Best to try fdisk -l to work out what's what.
    A big problem with image management is that almost every brand of SD card has a different number of blocks for a different capacity size. It is hence not easily possible to image a Sandisk 32GB card and write it to a Samsung 32GB card, at least without some intervention. If you check fdisk's output and the size of the destination device is equal to or larger than the image file, you don't need to do anything. But if it's the other way around, even by a few kB, you will need to take some action. The easiest way to deal with this issue is to edit the image file by mounting it as a loopback device, resizing the main partition smaller (ideally, as small as possible to give you the widest latitude to image to other cards, but with a margin to allow it to boot), truncating the image file, writing it to your SD card, booting up and resizing the partition to fill the card again (e.g. via sudo raspi-config).
    You will find that running Linux is actually quite advantageous in this regard, because these kinds of things can be more easily accomplished under Linux than Windows (for example).
    - Gough
  • gdstew
    0 gdstew over 5 years ago in reply to cstanton
    To expand on some of these points:
    Most desktop Linux distros will offer the option to extract a compressed file when you right click on it without needing to add any programs.
    I know Debian, Devuan, Linux Mint, and I believe Raspbian will because I've used them all to do so (it's been a while with Raspbian).
    To find out which /dev the SD card is using you can also use (using sudo or as root:):
    fdisk -l
    Disk /dev/sda: 29.8 GiB, 32010928128 bytes, 62521344 sectors
    Units: sectors of 1 * 512 = 512 bytes
    Sector size (logical/physical): 512 bytes / 512 bytes
    I/O size (minimum/optimal): 512 bytes / 512 bytes
    Disklabel type: dos
    Disk identifier: 0xaeedd120
    Device     Boot Start      End  Sectors  Size Id Type
    /dev/sda1        2048 62521343 62519296 29.8G 83 Linux
    As long as you know the size of the SD card, 29.8 GiB  for a 32 GB SD card on the first line in the response, then it is easy to know which
    device (/dev/sda also on the first line) it is using. It would be a good idea to properly remove any other SD cards before doing this just to
    be sure you find the right one.
    I always use dd bs=1M status=progress if=image file of=/dev/sdX (of=/dev/sda from the fdisk command above)
    I have probably written 30+ Raspbian image files using this without any problems since the first revision of the Pi was released. I have also
    used it for several other SBC OS images with no problems. The --status=progress  will display a progress message while the image is being
    written although I am still having trouble figuring out exactly what it is displaying.  The progress display message also stops well before the next
    shell prompt is displayed while waiting for the (SLOW) write to the SD card to finish.
    I use a block size of 1M because you can't do much to speed it up other than use a SD card with a faster write data rate because that is what
    slows it down the most by far.
  • gdstew
    I almost forgot. The Raspberry Pi Foundation recently released a new SD card image writing utility for Windows, macOS, and Ubuntu.
    Since what I currently use works fine for me I haven't tried it so I don't know how good it is but here is a link for it:
    https://www.raspberrypi.org/blog/raspberry-pi-imager-imaging-utility/
  • embeddedguy
    Thank you people.
    I will try dd first, also see what fdisk has to offer.
    BTW, I am not doing my P.hD. on SD card images and utilitiesimageimage
    0 Jan Cumps over 5 years ago in reply to embeddedguy
    Once you solved this in linux, you will be image
  • colporteur
    0 colporteur over 5 years ago
    Check out this posting Introducing Raspberry Pi new imaging utility I have used the tool recommended by clem57 it has worked consistently.
