Ask an Expert Forum Stuck on Experiment 11: Make Electronics
  • Answers 2 answers
  • Subscribers 304 subscribers
  • Views 1849 views
  • make: electronics
See a helpful answer?
opalko
opalko over 5 years ago
I am working on experiment 11 and am stuck with a non-functioning project.  I substituted 0.1uF caps for the 3.3uF listed in the book as 0.1uF were the largest ceramic caps I have..maybe it won’t do anything I can see with 0.1uF’s?  Can I use polarized 3.3uF caps in this experiment? In any case the LED does not light up with the 0.1uF's.
I checked the voltages at various points and  get 9V wherever there are connections to the ground rail. I also tested all of the transistors and LED in the previous experiment 10 which works.  I have rebuilt this one twice with same result and can’t see my mistake.
I am hoping someone can spot what is wired incorrectly in my circuit, photos follow including schematic from book in this album:
https://photos.app.goo.gl/FaNcrS1WVVWmyyAYA
Regards
Robert Opalko
  • beacon_dave
    beacon_dave over 5 years ago +4 verified
    Looks like you may have swapped the 470kΩ resistors with 470Ω resistors ?
  • opalko
    opalko over 5 years ago in reply to beacon_dave +3
    Aaaaaagh
  • Andrew J
    Andrew J over 5 years ago +2 suggested
    If it helps Robert, I followed that book and made similar mistakes with exactly the same reaction as yourself . Very easy to do but I can confirm that the experiments do work and are correct. There are…
  • beacon_dave
    0 beacon_dave over 5 years ago
  • opalko
    0 opalko over 5 years ago in reply to beacon_dave
    Aaaaaagh
  • Andrew J
    0 Andrew J over 5 years ago
    If it helps Robert, I followed that book and made similar mistakes with exactly the same reaction as yourself image.  Very easy to do but I can confirm that the experiments do work and are correct.  There are a couple of mistakes in book 2 but they are pretty obvious.  You may also find that some parts are nigh-on impossible to come by without spending ridiculous amounts of money but there are workarounds you and work out.
  • jc2048
    0 jc2048 over 5 years ago
    Positive to collector, negative to the base of the opposing transistor.
    Transistors: The Astable Multivibrator (Featuring SuperLEDman).
