Ask an Expert Forum Hi, I'm looking for a female to female adapter for a standard dc 9v power supply.
  • Answers 2 answers
  • Subscribers 337 subscribers
  • Views 1460 views
See a helpful answer?
jodonova
jodonova over 5 years ago
I want to connect this
https://www.muziker.ie/boss-psa-230s
to this
https://www.boss.info/en-ch/products/pcs-20a/
    dougw over 5 years ago +5 suggested
    DC Power Female to Female Jack Adapter 2.1x5.5mm These are available at Walmart - who would have thought of them as an electronics outlet?
    shabaz over 5 years ago +3 suggested
    Hi Jonathan, If you can't find it (I've not seen such a thing although it may exist), you can get two connectors on flying leads and connect them back-to-back. Or just chop off the end of the power supply…
  • rsc
    rsc over 5 years ago in reply to dougw +1
    Walmart is becoming another Amazon - if they don't have it, they know someone who has it.
    0 shabaz over 5 years ago
    Hi Jonathan,
    If you can't find it (I've not seen such a thing although it may exist), you can get two connectors on flying leads and connect them back-to-back. Or just chop off the end of the power supply and the end of the chain of plugs, and join them together.
    Here's a socket on a flying lead (as mentioned, two could be wired back-to-back)
    To wire them, a soldering iron can be used and then heatshrink, or there's various other options, an electrician may have easy-install connectors and a small box to house the connections. Or crimping metal tubes are available if a crimp tool is handy. Lots of options.
    0 dougw over 5 years ago
    • Vote Up +5 Vote Down
    0 dougw over 5 years ago in reply to dougw
    By the way, although these are advertised as female and it is obvious why, by the convention I was taught the connector with the pin is always the male, so these would be male connectors.
    What sex would you call them?
  • rsc
    0 rsc over 5 years ago in reply to dougw
