Ask an Expert Forum Looking for technical solution package
  • Subscribers 314 subscribers
  • Views 1224 views
See a helpful answer?
sabah.launay
sabah.launay over 4 years ago
Hello all
I am developing an app for children with disabilities. I need devices to collect data for my app and I would need an expert advice on which I should by from STelectronics via Farell
thanks a lot for your help
Sabah LAUNAY
    dougw over 4 years ago in reply to sabah.launay +1 suggested
    It still is not clear what you are trying to measure or record, but video cameras are about as general as you can get. I have designed and built many sensors and machines that measure and exercise motor…
    0 DAB over 4 years ago
    You can start by helping us understand your application.
    There are a wide range of disabilities. Which ones are you going to address?
    What type of data, number of bits, how often, data storage, data processes?
    Given your brief description, there are many possibilities.
    The first things experienced developers do is document their requirements. That helps them understand the magnitude of the project.
    Next you do a design analysis to look at critical issues that will drive component selection.
    Then you look at the project budget. Now you are ready to consider various component options and begin trade off analysis.
    The more you know helps you quickly narrow down your design choices.
  • sabah.launay
    0 sabah.launay over 4 years ago in reply to DAB
    Hello DAB
    Thanks for your advice.
    I am Information System engineer and knows about project phases to develop an app.
    my need is not for developing my app by to collect data on human motion
    my app address many features to help médecine in qualifying and decide wich care is better for motor disabilities
    I would need a solution like captors that help me collect data in disabled child.
    Which dispositif is the best the more precise
    regards
    Sabah
    0 dougw over 4 years ago in reply to sabah.launay
    I have designed and built many sensors and machines that measure and exercise motor control, range of motion and muscle performance of most parts of the body in people with injuries and disabilities. Each device has physiotherapy applications, which it was designed to to be used for, and it is pretty obvious which ones apply to any particular application. The effectiveness of a physiotherapy program depends on tailoring the regimen and the way the devices are used to individual situations.
    0 DAB over 4 years ago in reply to sabah.launay
    We still need more detail on what you think you want to measure, sensors you want to use and what do you want to do with the data.
    Converting data into information is an involved process. The more detail you give us the better we can guide you to the next step.
