Ask an Expert Forum 70 volt PA speaker punch down for 19" rack
  • Answers 3 answers
  • Subscribers 306 subscribers
  • Views 1266 views
  • punchdown
  • 70 volt
  • structured wiring
  • pa
See a helpful answer?
stevedahl
stevedahl over 4 years ago
I'm cleaning up a PA system for a school with 140 speakers in one zone. All of the wires from the speakers are making a home run back to the mechanical room. Currently they are all wire nutted in parallel  (daisy chained wiring arrangements). I'd like to clean this up to some kind of 19" rack mounted punch down panel . Does anyone know of a panel on the market that would allow me to easily create this?
  • beacon_dave
    beacon_dave over 4 years ago +4 verified
    Perhaps use standard DIN terminal mounting rails with 19" rack mount ears at either end ? You can get them off-the-shelf like: https://www.canford.co.uk/Index/19-inch-rack-DIN-rail-terminal-frames/CANFORD…
  • beacon_dave
    beacon_dave over 4 years ago in reply to stevedahl +2 suggested
    Just use staggered terminal jumper bars to connect every second terminal together (skipping over one terminal each time). All even numbered terminals are tied together and all odd numbered terminals are…
  • stevedahl
    stevedahl over 4 years ago in reply to beacon_dave +2 suggested
    Hello Dave; Thank you for all of the great advice, The DIN rail was the key. I did find this on Amazon which solved the issue of adding all of the speakers with out too many jumper wires. https://www.amazon…
  • beacon_dave
    0 beacon_dave over 4 years ago
    https://www.canford.co.uk/Index/19-inch-rack-DIN-rail-terminal-frames/CANFORD-RACK-MOUNTING-DIN-RAIL-FRAME#Image-2
    With DIN terminals you can group and bus as you like to customise it to your needs.
  • stevedahl
    0 stevedahl over 4 years ago in reply to beacon_dave
    Thank you Dave, that was excellent advice.
    Now the next piece. All of the Din connectors have a single pass through. Have you seen a din connector that maybe has 50 connections one each side of the DIN connector and one side is bonded together and isolated from the other side that is bonded together? This would easily allow me to place each pair of speaker wires in parallel?
  • beacon_dave
    0 beacon_dave over 4 years ago in reply to stevedahl
    Just use staggered terminal jumper bars to connect every second terminal together (skipping over one terminal each time). All even numbered terminals are tied together and all odd numbered terminals are tied together onto two separate buses.
    Add each speaker to a pair of adjacent terminals and they are now connected in parallel. Easy to re-jumper if you later want to create separate speaker zones in future.
    Terminate all of your speakers on one side of the DIN rail terminal bock and your amplifier on the other side.
    Some info on jumpers here:
    Wiring Jumpers Part 2: Types and How we Use Them - YouTube
    Using jumpers to wire every other terminal:
    Terminal Block Jumpers - They Can Save You Time, Money, and Headaches - YouTube
  • stevedahl
    Hello Dave;
    https://www.amazon.com/gp/product/B08XPX5CDQ/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    ANMBEST 2 In 16 Out Terminal Blocks Module, 25A DIN Rail and Panel Mounting Power Distribution Breakout Board for PLC Servo Power Amplifier
    0 dougw over 4 years ago
    That brings back ancient memories of crawling around wiring a whole (new) building with a big PA system and transformers at every speaker. I think we used massive barrier strips, but we are talking decades ago, so I can't be sure what the interconnects looked like. The amp was a Bogen.
  • stevedahl
    0 stevedahl over 4 years ago in reply to dougw
    We seldom do 70 volt systems any longer. Most of our PA systems are now IP based.
    Again Thank you for the insight on the DIN rail.
