Ask an Expert Forum Oscilloscope
  • Replies 20 replies
  • Answers 8 answers
  • Subscribers 309 subscribers
  • Views 3283 views
See a helpful answer?
Oscilloscope
electronicslearner101
electronicslearner101 over 4 years ago
I was wanting an Oscilloscope but they are very expensive. Would it be possible to get one under 50 dollars that is at least decent? If so…how and where? Thanks!
    dougw over 4 years ago +8 suggested
    You can get a 200KHz scope for $27... Probably most useful if you are looking at audio frequencies or sensor signals. Or a 100 MHz scope for $73...but still just 1 channel. I have not tried either one…
  • scottiebabe
    scottiebabe over 4 years ago +6 suggested
    If your willing spend a little bit more you may want to consider the USB scope recently presented on E14: Workbench Wednesdays 38: Which Oscilloscope Form Factor Is Best For Me? Which features the MP720016…
    Jan Cumps over 4 years ago +5 suggested
    Under 200 € will be hard. I worked with this one: 3107569 3107569 with balearicdynamics It works well. Just over 200. You may find second hand analogue ones for 50 € but expect age problems such as bad…
    0 Jan Cumps over 4 years ago
    Under 200 € will be hard. I worked with this one: 31075693107569 with balearicdynamics
    You may find second hand analogue ones for 50 € but expect age problems such as bad contacts in switches and potentiometers; overaged electrolyte capacitors...
    • Vote Up +5 Vote Down
    0 dougw over 4 years ago
    I have not tried either one. Read the specs to see if they are suitable for your needs.
    I have a DS213 which has more channels, which I like because it is very portable, but it is a bit more expensive.
    • Vote Up +8 Vote Down
  • scottiebabe
    0 scottiebabe over 4 years ago
    Which features the MP720016 US PC USB Oscilloscope:
    https://canada.newark.com/multicomp-pro/mp720016-us/pc-based-osc-2-ch-25mhz-100msps/dp/10AH2399
    • Vote Up +6 Vote Down
    0 jw0752 over 4 years ago in reply to dougw
    Hi Doug,
    I have built several of these kits and they work very well. They even have a measurement array that will print on the screen with a dozen or so of the most common measurement parameters.
    Here is a posting I did on building one a while back:
    https://www.element14.com/community/people/jw0752/blog/2017/04/25/building-the-dso-shell-15001k-oscilloscope?sr=search&searchId=42926c9d-064e-43ed-8171-ff0326af0f21&searchIndex=0
    0 michaelkellett over 4 years ago
    To give you good advice I really need to know what you want to do with an oscilloscope and where you are (country).
    In the US and Europe there is a good chance of getting a second hand scope, although the $50 is very tight.
    There is a 20MHz scope on Ebay (UK) right now for £30.
    The alternative is you may be able to get one for free - a lot of old gear at sub £100 value just gets thrown out.
    My Gould dual channel 20MHz scope came from a skip !
    Some of the cheap new stuff is very poor indeed.
    The cheapest I would recomend is the Picoscope 2204A at £105.
    Here's one on Ebay (UK) now:
    https://www.ebay.co.uk/itm/154481466052?mkevt=1&mkpid=2&emsid=e112358.m43.l1123&mkcid=8&bu=43464259003&osub=-1%7E1&segna…
    0 Jan Cumps over 4 years ago in reply to michaelkellett
    If electronicslearner101 was experienced in electronics, this could be a good idea.
    But most of the times, if you don't know electronics (and his user name indicates that that is the case), buying an old analog scope leads to disappointment. If they survive the expensive shipment.
  • electronicslearner101
    0 electronicslearner101 over 4 years ago
    Thank you guys so much for your responses. And I am pretty experienced in electronics as I have been working in the field of electronics as a hobby and learning opportunity for the future. So Jan Cumps, thanks for the response and I have already purchased the 1 channel 100MHz Oscilloscope. Thanks!
    0 michaelkellett over 4 years ago in reply to electronicslearner101
    It would be great if you blogged about how you get on with it.
    0 michaelkellett over 4 years ago in reply to Jan Cumps
    On my browser the OP's name shows as his name - I only saw the electronicslearner101 tag when you posted it image
    Is there any way to set things up to show name and tags ?
