Ask an Expert Forum Where do I start!
  • Locked Locked
  • Replies 13 replies
  • Answers 9 answers
  • Subscribers 340 subscribers
  • Views 4022 views
See a helpful answer?
Where do I start!
philanirsa
philanirsa over 5 years ago
I'm an engineering undergraduate, majoring in Mechanical engineering. I have really fallen in love with programming and electronics.
I love building things, although I haven't made anything. I'd like to know where can I start. I feel like there's a huge gap in my knowledge of electronics. Honestly BJTs, op-amps, and transistors kind of went over my head in sophomore year.
Please help me out, any suggestions on starting material would help me out.
Regards
    jw0752 over 5 years ago +8 suggested
    Check out Jeremy Blum's Exploring Arduino. It is a well presented series of building experiments that use the Arduino to demonstrate some of the basic capabilities of the board. This may give you some…
  • colporteur
    colporteur over 5 years ago +7 suggested
    Well your profile suggests that you are not knew to the community. Maybe you took a hiatus for studies so welcome back. I worked in electronic for 17 years and then my career diverted to computers for…
  • neilk
    neilk over 5 years ago +6 suggested
    Jeremy Blum's Arduino Tutorials got me started. Neil
    0 jw0752 over 5 years ago
    Check out Jeremy Blum's Exploring Arduino. It is a well presented series of building experiments that use the Arduino to demonstrate some of the basic capabilities of the board. This may give you some ideas for expanded builds.
    https://www.exploringarduino.com/
    • Vote Up +8 Vote Down
  • neilk
    0 neilk over 5 years ago
    Neil
    • Vote Up +6 Vote Down
  • philanirsa
    0 philanirsa over 5 years ago
    Thank you so much for your responses, much appreciated. I will check him out.
    Regards
    0 genebren over 5 years ago
    There is a wealth of knowledge and learning material her on this site.  Read into the details of projects or check out the learning center Learning Center  which has many ways to learn more about electronics.  Within the learning center is an area with introduction to electronics videos The Learning Circuit  produced by makerkaren . These videos are a good source of simple explanations of how electronics work.
    Look around.  Ask questions. Find things that spark an interest and then repeat the steps and learn as you go.
    There are a lot of knowledgeable and friendly members here that can help you get started.  By finding areas of interest, it will help you narrow down your questions, which in turn will make it easier for other members to help you.
    Good luck on your journey!
  • colporteur
    0 colporteur over 5 years ago
    I worked in electronic for 17 years and then my career diverted to computers for system administration and design engineering. After a forty year career, twenty away from electronics, I have started to do more than dabble in the electronic component side. A friend has a model railroad that he is building. I to feel the electronic knowledge gone stale but I have discovered the foundation knowledge comes back and can still be used to build on. I have used this community to answer simple questions like transformers. Using transformer secondary windings
    Simple projects using microcontrollers (Arduino) or single board computers (Raspberry Pi) can get you back into the stream. What are your personal interest? In my example above, I don't do model trains. I do like computers. My contribution is animation on a railroad layout. Raspberry Pi's running a drive-in movie theatre or Arduino honking a car horn and turning on the headlights or simulating people walking using motors. All a blend of technology knowledge.
    My preference would be SBC. You have developed a number of knowledge points in engineering. A SBC projects gives you some success from those knowledge points while enabling you to improve in some other areas. Think of your interest areas and search microcontroller or SBC projects in that interest area. Take for example gardening and Arduino. You would be surprised the tech guys that have combines the two different interests.
    • Vote Up +7 Vote Down
  • philanirsa
    0 philanirsa over 5 years ago in reply to genebren
    Thanks alot Gene, Sean mentioned the same thing to me, about finding an area of interest and exploring it. I will definitely be using the information on the site, didn't know you had them.
    Honestly the "internet on the box" reminded me of this community. I joined and then forgot, I know I'm guilty. But it was during reading the documentation for that DIY project, that I realized I don't know anything about this stuff.
    Thanks again for the insight, looking forward to the journey.
    Regards
    0 DAB over 5 years ago
    Go to the Library and pick up the Make Magazine books on electronics and projects.
    They do a good job of walking newbies through the basics to get them up and running.
    • Vote Up +5 Vote Down
  • kmikemoo
    0 kmikemoo over 5 years ago
    philanirsa  Since you like to build... Buy the Arduino, a breadboard, some LEDs, some 330 ohm resistors and some Dupont jumper wires and start wiring stuff up.  Making things happen will inspire you to try more complex things.  I still take apart things that I'm going to throw away and see if I can scavenge usable parts off of them.  I rarely get usable parts, but every once in a while, I score an LED (with long enough leads to keep), a relay or a buzzer.  I've also recovered usable voltage regulators with heat sinks.  You're better off buying a resistor assortment rather than trying to scavenge those.
  • philanirsa
    0 philanirsa over 5 years ago in reply to kmikemoo
    Awesome Mike, that's great advice. I like keeping stuff things that don't work anymore, with the hope that one day I could fix them, although I never do.
    I think that's a great way to apply things I'll learn. Scavage parts and make useful things. I like it.
    I feel like a kid haha. Awesome advise, thanks.
    Regards
  • Sean_Miller
    0 Sean_Miller over 5 years ago
    If you are on a budget or are tight on space, a good gateway to robotics is using AutoDesk Fusion 360 and the Unity Game Engine.  It's all free.
    You'll learn .Net coding, learn to design for fabrication, learn circuit design, and learn how to make things move and respond to its environment.  All transferrable skills to future robotics projects with no money down.
    For my bigger projects such as CNC, I do them 100% in Autodesk Fusion 360, including the circuits, before getting out of the easy chair.  It's a good pass time during terrible Netflix movies.
    See ya',
    Sean
