Ask an Expert Forum Your thoughts on processor power dissipation
  • Subscribers 324 subscribers
  • Views 646 views
  • Processor
  • power
  • dissipation
See a helpful answer?
Former Member over 15 years ago
Conservation of energy says that energy cannot be created or destroyed, only converted, then what happens... if a microprocessor consumes 50 watts, and only 20% is converted into heat... How is the remaining wattage dissipated? Does the processing of information itself consume power?
  • mberman
    0 mberman over 15 years ago
    Hi Martin,
    I think you know the answer to your question.  Yes, of course, the rest of the energy is used by the microprocessor to provide fast computations, process commands and provide drive to the output devices.  This is true of all electronic, electrical and mechanical devices.
    Kind regards,
    Mel
    0 Former Member over 15 years ago in reply to mberman
    Ah, right, it also helps to drive other componets. I was too focused on the processor itself. Thank You for your input image
  • mberman
    0 mberman over 15 years ago in reply to Former Member
    You are most welcome Martin!
    Remember that most of the energy is used to do the "work" of the device.
    Same goes for humans.
    All the Best.
