Ask an Expert Forum Which interface kit and microprocessor has to be used to make a autonomous robot car using JAVA?
  • Subscribers 306 subscribers
  • Views 474 views
  • agent
  • car
  • robot
  • java
See a helpful answer?
I have to use JAVA AGENTS to do image processing and controlling stuff.
  • Catwell
    0 Catwell over 14 years ago
    Vignesh,
    JAVA runs on virtual machines, so many dev-boards would work.
    I am a big advocate of PIC processors. Try using the PICKIT 2 Starter KitPICKIT 2 Starter Kit. At its heart is a PIC16F series uC. Which you could easily port your software to a custom board featuring that IC at a later date.
    This person did RC control via JAVA on the same kit:
    This video is unavailable.
    You could also try LeJOS, which brings JAVA to Lego Mindstorm NXT platform. See the following projects based on Legos. The configurability lends itself to easy RC applications.
    Androids play with Legos
    Pancake Bot is made of LEGOs
    3D scanner built from LEGOs
    And a RC car based on NXT and LeGOS:
    More at : http://www.juanantonio.info/jab_cms.php?id=228
    Post your project on element14 as your progress.
    Cabe
    http://twitter.com/Cabe_e14
