Ask an Expert Forum Need help with a Larson Scanner build...
  • Subscribers 302 subscribers
  • Views 381 views
  • schematics
  • scanner
  • larson
  • electronics
See a helpful answer?
I've built plenty of these with decade counters, Arduino, Pic, Propeller, and other microcontrollers. The thing is I want to go old school and build one out of nothing but resisters, diodes, capacitors, and resistors. I was a bit fan of Knight Rider and Battlestar Galactica as a kid. Those are the shows that started my obsession with the Larson Scanner curcuit.I am currently trying to use a design for a dual LED flasherwith a larger series of transisters and other componants. I'm using rectifier diodes to keep the loop from feeding backwards into the trigger stage. That is where I keep running into trouble. I get premature triggers across all the LEDs in the sequence. Any schematic suggestions?
  • Catwell
    0 Catwell over 13 years ago
    Jarren,
    Post a schematic of your circuit. We will put some analysis on it.
    Also, try building another or re-building the one you have. Most of the time, one-of-a-kind circuits malfunction due to build issues.
    Cabe
    http://twitter.com/Cabe_e14
