Ask an Expert Forum Parallel port under XP?
  • Subscribers 303 subscribers
  • Views 418 views
See a helpful answer?
YT2095
YT2095 over 13 years ago
I really need some help with my Parallel port under XP, I have a programmer for PIC chips, that`s quite ancient, and it works well when I use a windows 98 machine, and yet under XP I get IO Error?
the Parallel port seems to do Some things to the programmer in way of it being recognised as being hooked up to a computer, but`s all.
and I know there`s nothing wrong with it or the leads etc...
it`s Purely a windows XP issue.
Anyone know how I can fix this?
Cheers image
    0 Former Member over 13 years ago
    XP (NT and newer) prevents direct access to IO space. one workaround is to use a virtual PC (microsoft, vmware, vbox) to run windows 98, 95, or dos on a virtual machine that has the lpt port enabled in the settings. see http://www.essjae.com/virtualization/WinVPC-InstallingWin98.pdf
    A second method is to use a kernel mode driver that allows io access. this will only work if your programmer software uses the older version of InpOut32.dll to controll the port. see http://logix4u.net/component/content/article/14-parallel-port/index.php?option=com_content&task=view&id=16&Itemid=1
  • YT2095
    0 YT2095 over 13 years ago in reply to Former Member
    Thanks for that!
    currently I`m running the old s/ware on an equally old machine and it`s working well, but I think I`ll try the second of your 2 ideas when I get a bit more bench room to drag out my old IBM laptop and move all this other kit away.
    I need to leave my original system intact as I use my EPROM programmer on it (oddly that does work?).
    Cheers for a good and timely answer image
