Ask an Expert Forum Terminal block current rating
  • Subscribers 313 subscribers
  • Views 269 views
See a helpful answer?
Hi, first post here.  I'm currently working on a project and right now I am working on a power distribution board.  The board simply splits a 5V supply out to about 25 header plugs.  Each header will draw about 0.5A, lets say 0.6A to be safe.  The supply will be connected using a wire-to-board screw terminal (the green ones).  The rating on the package says the terminal block can handle 10A@300V, I need 15A@5V.  I'm guessing I should get a higher rated terminal block but just checking if its actually related to power and not current.
