Ask an Expert Forum Marvell Ethernet Switch: cascading devices via RGMII
  • Subscribers 338 subscribers
  • Views 1391 views
  • marvell
  • hardware
  • dsa
  • rgmii
  • distributed_switch_architecture
  • ethernet_switch
  • 88e6352
See a helpful answer?
Hi
I have a design using two Marvell 88E6352 Gb Ethernet switches. They are connected together via RGMII (Mac to mac rather than mac to phy).
Can I use this switch to switch interface to cascade the switches to act as one? I think it is more usual to use SGMII for this but believe a no phy chip to chip interface to still be valid.
I can see the clocks working from each device but the data lines are inactive.
I have tried setting Distributed Switch Architecture on for these ports, forcing the link and speed settings etc – but the data lines never move!
I am using port 5 of the device and have confirmed it to be in RGMII mode and enabled.
Any guidance would be helpful.
Steve
    Hi Steve,
    Did this get resolved?  Did it work? If so can you share the schematic of how you connected them together or point me towards any application notes?
    Cheers - David
