Ask an Expert Forum Voltage Doubler
  • Subscribers 340 subscribers
  • Views 770 views
See a helpful answer?
Voltage Doubler
I've run into a bit of a snag on a project at work. In trying to fit a torque sensor to our product, I will need to up the input voltage from 4.9VDC to 9-12VDC at 48-88mA.
To complicate matters further, I have a very small space to work with.
Since time is of the essence, I am open to ANY suggestions.
  • corbin.sl
    0 corbin.sl over 14 years ago
    You could make a voltage doubler with just a few capacitors and diodes.  Shouldnt take up much space. Check this out http://en.wikipedia.org/wiki/Voltage_doubler
  • Catwell
    0 Catwell over 14 years ago
    Brandon,
    What type of signal is coming our of your sensor?
    Cabe
    0 e14 Contributor over 14 years ago in reply to Catwell
    The output is rated at 205.85mV/N.m
    Force and torque sensors typically have outputs rated in mV/V.
    We actually use this torque sensor with another one of our products. I am fairly certain I was able to isolate the voltage doubler and voltage divider circuits from the original application and adapted it to this new application. I won't know until it goes for calibration. Its getting pretty tough to trace out a circuit without a schematic these days.
