Ask an Expert Forum Help with Ti's PCM1704 versions
  • Subscribers 302 subscribers
  • Views 451 views
See a helpful answer?
drysteve47
drysteve47 over 13 years ago
Could you please confirm which version of Ti's version of the PCM1704U-KPCM1704U-K I would need to replace a faulty Brown Burr PCM1704U-KPCM1704U-K?
    0 michaelkellett over 13 years ago
    Burr Bown are part of Ti and have been for some time.
    What does it say on the duff chip (and how do you know that it's duff ?)
    Michael Kellett
  • drysteve47
    0 drysteve47 over 13 years ago in reply to michaelkellett
    It's in a multi channel AV amp.
    Checked as faulty by scoping inputs, then removed old chip from board and swapped by another one on the same board (centre channel).
    Channel then worked ok and fault had moved to the centre channel.
    All that's printed on IC is "BB PCM1704U-KPCM1704U-K"
    I think that the Ti version "PCM1704U-K" is a suitable replacement.
    Many thanks for your help.
    Regards
    Stephen Woodrow
    This electronic message contains information which may be privileged and
    confidential. The information is intended to be for the use of the
    individual(s) or entity named above. If you are not the intended
    recipient, be aware that any disclosure, copying, distribution or use of
    the contents of this information is prohibited. If you have received this
    electronic message in error, please notify us by telephone or e-mail (to
    the number or address above) immediately.
