Ask an Expert Forum Extraction Tool needed
  • Subscribers 318 subscribers
  • Views 1232 views
See a helpful answer?
Need to know if there is an extraction tool for part number 157-8643,
MULTICOMP - 2260(5560)T - CRIMP SOCKET, 20 - 24AWG
  • Nate1616
    0 Nate1616 over 13 years ago
    Are you trying to remove the socket from the housing?  if you are, this is what you can use http://www.ebay.com/itm/crimp-pin-EXTRACTOR-ejector-removal-tool-molex-jst-hrs-amp-tyco-wurth-terminal-/251198282804?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item3a7c959c34
    0 Former Member over 13 years ago in reply to Nate1616
    Thank you perfect
    Regards
    Rory Armstrong
    Business Operations Manager
    *[image: Description:
    http://amo2.flsecure.com/applemail-rick/ezy2c-logo.jpg]
    DIVISION OF FLEET LOGISTICS PTY LTD*
    Mobile: 04 28 42 1104 | Phone: 02 66 42 1100 | *Facsimile: *02 66 43
    3290 | *Email: *rory.armstrong@ezy2c.com <tony.ellem@ezy2c.com> | Web:
    www.ezy2c.com
    This email and its contents are confidential and are for the intended
    recipient only.  If it has been received in error please contact the sender
    immediately.
    Sent: Thursday, 20 December 2012 11:46 a.m.
    To: Rory Armstrong
    Subject: - Re: Extraction Tool needed
    image: element14<http://www.element-14.com?CMP=e14notificationemail_header>
    created by Nate Chapman <http://www.element14.com/community/people/Nate1616>in
    Experts - View the full
    discussion<http://www.element14.com/community/message/66242#66242/l/re-extraction-tool-needed>
    Are you sure it will work on a square connector as the ebay add says they
    are only good for round connectors
    Regards
    Rory Armstrong
    www.ezy2c.com
    immediately.
    To: Rory Armstrong
  • Nate1616
    0 Nate1616 over 13 years ago in reply to Former Member
    Sorry about that.  I was just giving you a link to ebay so you could see what you were looking for.  I didnt mean thats the one you need..  Sorry again for the confusion but this one will work with your component.  http://uk.farnell.com/te-connectivity-amp/539972-1/extraction-tool/dp/9909125?Ntt=9909125.
  • Nate1616
    0 Nate1616 over 13 years ago in reply to Nate1616
    If you would like to make sure about this i would contact a rep from Franell before you order.
  • Nate1616
    I feel bad for the confusion earlier so i talked to a rep for you and yes this item will work http://uk.farnell.com/te-connectivity-amp/539972-1/extraction-tool/dp/9909125?Ntt=9909125.
