Ask an Expert Forum 17in monitor configuation
  • Subscribers 316 subscribers
  • Views 473 views
See a helpful answer?
Hi, I am a newbie with the Raspberry Pi computer
I got the Plug n play kit from CPC at Christmas, it works fine on my 26in TV using the RGB connection with an HDMI to RGB converter.
The trouble starts, when I tried to connect to an old 17in monitor. The icons are off screen left and the raspberry in the centre of the screen is vertically elongated. Can I change the display
settings whilst connected to the TV, to suit the 17in monitor. Can you please help.
    0 Former Member over 13 years ago
    You could try a hdmi to vga converter from the elment store. Also are there any controls on the back of the monitor you can adjust?  (horz/syn) And you may want to try the monitor on another pc to see if it's the same problem. Couple things to look at...later.
  • amgalbu
    0 amgalbu over 11 years ago
    probably your old monitor does not support the default resolution of the Rapsberry Pi
    You can have a look here
    http://elinux.org/RPiconfig#Video
