Ask an Expert Forum LM3886T/NOPB
  • Subscribers 330 subscribers
  • Views 834 views
See a helpful answer?
LM3886T/NOPB
I need a pair of LM3886TF/NOPBLM3886TF/NOPB chips to repair an audio amplifier.  I noticed that there is a cheaper LM3886TF/NOPBLM3886TF/NOPB/NOPB version available but I'm not sure if is a direct replacement or not.  There does not seem to be any information in the data sheet specific to the NOPB version and the only real difference I can see on the Farnell page is the amplifier class (B for LM3886T and AB for the NOPB version).  This suggests to me that the NOPB version may need a larger heatsink.  Can anyone help?  I am fairly sure that NOPB means it is a no lead version but can I use it as a cheaper replacement?
Ray
    0 michaelkellett over 13 years ago
    As far a I am aware the NOPB addition to the part number just means that it is lead free -  this isn't clearly spelt out on either the datasheet or the TI product webpage.
    Michael Kellett
    0 Former Member over 13 years ago in reply to michaelkellett
    Thanks for the reply.  So I should be able to use the NOPB version as a direct replacement?  Just seems odd that the NOPB version is less than half the price of the ordinary one.
    Ray
  • jason721
    0 jason721 over 13 years ago in reply to Former Member
    Ray,
    The NOPB in National Semi Part numbers is for RoHS compliance. So yes it will be a direct substitute. From what I have seen when both versions are still offered after some time the compliant versions do become cheaper then the originals. I'm figuring it is probably due to production quantities.
    Jason G.
