Ask an Expert Forum PIC MCU UART
  • Subscribers 338 subscribers
  • Views 560 views
See a helpful answer?
PIC MCU UART
Hi,  I am trying to transmit and recieve block of few bytes through USART. I am using PIC18F452 and PIC18F252 at two kits. I am programming in assembly language. Tranmission is @1200 baud and Procesoor clock @4Mhz.  My problem is,  I cant recieve byte unless insert a delay at transmitter. But it slows the communication. What could be the solution ?  concerned code is copied here. How to speedup the communication eliminating <> between consecutive bytes.  TRANS                        bsf RCSTA,SPEN    ;Enable serial port          bsf RCSTA,CREN    ;cont recieve mode          bsf RCSTA,RX9    ;9'th bit recieve enable                    movlw 0x33              ;for 1200 baud          movwf SPBRG                    bcf TXSTA,BRGH    ;Lo spped baud select          bsf TXSTA,TXEN    ;Transmit enable TXEN-1          bsf TXSTA,TX9    ;9'th bit transmit enable                              movff CMD_T,TXREG    ;byte to transmit          return  ;-----------------------------  TRAX            TX_L      bcf TXSTA,TX9D    ;CLR bit 9      movff PWM_D,CMD_T      call TRANS            call Delay1            TX_H      bsf TXSTA,TX9D    ;set bit 9      movff PWM_V,CMD_T      call TRANS         return   ...  Delay1            movlw    H'FF'      movwf   Dx  L2          movwf     Dy      clrwdt  L1    decfsz    Dy      goto    L1      decfsz  Dx      goto    L2      return  ;;;; recieve iterrupt service routine is .....  ISR_RX         btfss RCSTA,RX9D      goto LB      goto HB        HB     movff RCREG,FDBK_H      goto OVER_RCV        LB    movff RCREG,FDBK_L        OVER_RCV                    retfie        ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
  • i_droppa
    0 i_droppa over 13 years ago
    Hi, do you observe the TRMT bit (Transmit Shift Register Status)? It maybe helps to prevent writing in the TXREG before completed the transmission.
