Ask an Expert Forum Does attachInterrupt() work on getboard?
  • Subscribers 315 subscribers
  • Views 353 views
  • gertboard
See a helpful answer?
kev1nd
kev1nd over 13 years ago
Hi
I have a Gertboard (new rev) plugged directly into a Raspberry Pi.
For this test, I've connected button 3 to pin 2 of the Atmega (B3 to PD2), plus serial and programming connections as per the manual. I've tested the wiring is OK - a sketch with a digitalRead(2) can detect a change when the button is pressed.
My test sketch is:-
const int interruptPin = 2;
volatile int btnpress = 0;
void setup() {
  pinMode(interruptPin, INPUT_PULLUP);
  attachInterrupt(interruptPin, inter, CHANGE);
  Serial.begin(9600);
  Serial.println("Start");
void loop() {
  if (btnpress!=0)
    Serial.println("Interrupted!");
    btnpress = 0;
  delay(500);
void inter()
  btnpress = 1;
Unfortunately, press the button and no interrupt.
"attachInterrupt" isn't mentioned directly in the Gertboard manual, and none of the pre-loaded examples seems to included it.
So, are Interrupts actually supported?  If so, what am I missing here?
    Hi Kevin
    got an issue that strangely looks the same. I'm working with 433MHz RF transmitters and the RCSwitch Library.I'm getting fine on a traditional Ardiuno Uno board, but cannot get it work properly on the GB.
    Did you find a solution since you post your message ?
    thanks
