Ask an Expert Forum Launchpad MCU fails to load program
  • Subscribers 303 subscribers
  • Views 478 views
  • msp430
  • launchpad
See a helpful answer?
I am having some trouble loading a program onto a msp430g2302 using the launchpad platform and code composer studio 5.
I have tried using the msp430g2211 and msp430g2231 and these both load a simple blink program with no problems. But as soon as I put a msp430g2302 into my mspexp430g2 I get an error message saying "load program error" "<filepath> load failed" and the following information comes up in the console
MSP430: Trouble Writing Memory Block at 0xfffe on Page 0 of Length 0x2: Could not write device memory
MSP430: GEL: File: C:\Users\MR_ONE\launchpad\BlinkMe\Debug\BlinkMe.out: Load failed.
I change the device variant under properties to msp430g2302 and I have tested with two different msp430g2302. Is there anything else I could try?
  • danteo
    0 danteo over 12 years ago
    Hi Stephen,
    It may be something with the lanchpad you use, is it 1.3, 1.4 or 1.5?
    Here you can find some info about this issue: http://e2e.ti.com/support/microcontrollers/msp430/f/166/t/93945.aspx
    Maybe you need to update the firmware: http://processors.wiki.ti.com/index.php/MSP430_LaunchPad_Firmware_Update
    But read the comments from the update wiki page because sometimes it didn't end well.
    Dan
    0 Former Member over 12 years ago in reply to danteo
    The launchpad I am using is revision 1.4
    And I will try the firmware update and see if that will fix the problem.
